The client is experiencing an issue where links on their multilingual website are not adjusting to include the correct language prefix (e.g., '/ru/' or '/ar/') when switching languages. This occurs even when using Elementor dynamic links or manually pasting the links.
We recommend checking if the option "Adjust IDs for multilingual functionality" is enabled. You can find this option by navigating to WPML -> Languages in your WordPress dashboard. Enabling this option should ensure that links are correctly adjusted to include the language prefix for the current language.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the issue persists, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please don't hesitate to open a new support ticket in the WPML support forum.
Assisted by: Long Nguyen.
