Last updated by Kor 1 year, 11 months ago.
August 11, 2023 at 12:51 pm #14188651
emirE
Open website and change language to english
umutkul.com.tr
August 13, 2023 at 10:46 am #14192871
Noman
WPML Supporter since 06/2016
Before your ticket is assigned to one of my colleagues, I'd like to assist you with some initial debugging steps to expedite the support process.
It seems you have built the header/footer using the Elementor Header & Footer Builder plugin, and you have already set the elemntor-hf post type as Transltable from WPML >> Settings > Post Types Translation section.
Could you please try to re-save the header/footer templates and see if this resolves your issue.
If the issue still persists, please follow the below steps and let us know how it goes:
1. Please take a backup of your site first for safety reasons.
2. We have recently released WPML 4.6.5, could you please update it to the latest version and see if this resolves your issue?
You can update it from Plugins >> Add New page, click the Commercial tab, and then click the “Check for updates” button. Here is the screenshot for more details:
https://wpml.org/wp-content/uploads/2020/04/wpml-force-plugin-update-1.png
3. Please update all outdated plugins to the latest version especially Elementor, and Elementor Header & Footer Builder plugins, and see if this resolves your issue.
Looking forward to your update on the outcome of these steps.
Thank you
August 13, 2023 at 3:48 pm #14193537
emirE
Hello Noman,
I tried both things you advised but still there is a problem with espacially homepage. I realized the header and footer shows on other pages but i cant see them on home page
August 15, 2023 at 8:20 am #14201603
WPML Supporter since 08/2022
Thanks for your reply.
Upon reviewing your debug information, I have observed that the PHP limit for your "WP Memory Limit" is lower than the recommended 256MB or the required 128MB, as mentioned in the documentation found at: https://wpml.org/home/minimum-requirements/. To resolve this, I kindly request that you contact your hosting provider and request an increase in the PHP value for you.
The topic ‘[Closed] Elementor headers and footers not showing when language change’ is closed to new replies.
