You are facing an issue where the English version of your website's content is not displaying on the front end. You have tried several troubleshooting steps including refreshing and editing the English version, disconnecting and reconnecting the English page, creating new drafts in both Italian and English, disabling and updating the Breeze plugin temporarily, and clearing the WPML cache.
We have investigated your issue and found that the listing type should not be translated, as its custom post type (CPT) is set to be displayed as translated. We resolved the issue by deleting the translation of the ATTRAZIONI/POSTI DA VEDERE listing type. After removing the translation, the English listing now appears correctly.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Andrey 8 months, 2 weeks ago.
Assisted by: Andrey.
October 11, 2024 at 2:46 am #16277391
angeloS-19
I am trying to resolve an issue with the English version of my website hidden link where the contents are not showing on the front end. I have attempted several troubleshooting steps including refreshing and editing the English version, disconnecting and reconnecting the English page, creating new drafts in both Italian and English, disabling and updating the Breeze plugin temporarily, and clearing the WPML cache.
The English version contents are not showing on the front end of the website.
Can you check the root cause of why the English version contents are not showing?
October 11, 2024 at 4:04 pm #16280578
Andrey
WPML Supporter since 06/2013
How did you create this page? Have you tried with a new page?
Could it be that the page is in Draft? If so, try going to the English page using the WordPress editor and publishing it.
Does the issue persist if you temporarily deactivate all the plugins except WPML?
October 14, 2024 at 4:09 am #16283912
angeloS-19
Hi Andrey,
Thank you for your reply. We still did not try to disable the plugins. We will create a staging website first before running major changes on the website and we'll let you know.
Also, here are the following tests we have done so far however the issue persists:
- Refresh and edit the English version: hidden link
- Disconnect and reconnect the English page.
- Create a new draft in Italian: here: hidden link and in English: hidden link
- Create a new draft English Page here: hidden link (No Italian version)
- Disable and update the Breeze plugin temporarily.
- Clear WPML cache
If you could please check it for us to find the root cause of why the English version contents are not showing that would be great.
In case you need the login credentials, you can view them here: [removed]
Let me know if you need more information. Thank you very much!
October 14, 2024 at 8:06 pm #16287785
Andrey
I have removed the link with the access details.
October 15, 2024 at 7:21 pm #16292411
Andrey
Thank you for the details. I will check and let you know.
October 16, 2024 at 3:30 pm #16296668
Andrey
I noticed that the French listing shows content but not the English. I also noticed that if you deactivate the Unlimited Elements for Elementor plugin, the listing template doesn't display at all (inc. default language).
So the question is, how did you create a template for listings? It may not have been translated into English.
October 17, 2024 at 8:35 am #16298803
angeloS-19
Hi Andrey,
Thank you for your reply, the listing template comes from the theme package: TownHub by CTHthemes. It seems that the author used a custom post type. Since you mentioned that the template is not translated. I have followed the article here to translate the custom post type: https://wpml.org/documentation/getting-started-guide/translating-custom-posts/.
I tweaked some custom post-type settings here: hidden link however, still it did not work. I suspect there's an issue with the theme itself and it would be great if you help us to track down the root cause of the issue.
October 18, 2024 at 7:12 pm #16306146
Andrey
Hey,
I have further debugged this and discovered that the listing type should not be translated (as its CPT is set as displayed as translated). I have deleted the translation of ATTRAZIONI/POSTI DA VEDERE listing type, and this particular listing appears in English: hidden link
Have a nice weekend.
