I am trying to make sure the WPML plugin works properly on the website. I expected to see the Plugins (WPML) where I can update the verification code. The issue can be seen at: hidden link
I got an error: Uncaught Error: Class "DOMDocument" not found in /home/eliseber/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php:67. There has been a critical error on this website.
How can I make sure everything will work properly with WPML on my website.
Thanks for confirming it. To take a closer look at this issue, please provide temporary access (WP-Admin and FTP Login info) to your site (preferably staging site), so that I can look into your setup and debug the issue.
✙ I would additionally need your permission to deactivate and reactivate Plugins and the Theme and to change configurations on the site. This is also a reason the backup is essential.
Thank you
The topic ‘[Closed] Fatal Error problem’ is closed to new replies.
