Last updated by Andrey 1 year, 9 months ago.
Assisted by: Andrey.
July 20, 2024 at 3:46 am #15980660
mirteM
I deactivated Redis for a rather long time (almost a day) and no improvements.
July 20, 2024 at 8:59 am #15981093
mirteM
I found a workaround that works for me. I changed the settings to classic translator, then went to translation management. I selected a translation stuck in "progress" and added it to the translation queue again (this will cancel any translation already in progress). this did the job. So it is 100% not an issue with some other plugin.
July 22, 2024 at 4:37 pm #15988047
Andrey
WPML Supporter since 06/2013
Thank you for your messages.
Sorry for the delay. I was unavailable for some time.
The workaround seems reasonable to me. Does that work for you? If you are still experiencing this problem, I will keep checking. In that case, I would need new access credentials, as the ones you shared no longer allow me access.
July 22, 2024 at 5:42 pm #15988287
mirteM
Hey Andrey,
The workaround seems to be working for me so no further assistance is required. I do wonder though if there would be any future downsides of not using ATE. Will this way of doing things keep on working? It would still be nice to have it fixed in some future patch.
Including better support for Redis (other support question I posted long ago).
July 22, 2024 at 9:30 pm #15989397
Andrey
We are continually enhancing WPML. Although there are no downsides, ATE has additional capabilities, such as automatic translation.
I still recommend that you temporarily replicate the issue so we can resolve it properly. Which version of Apache are you using?
July 23, 2024 at 6:51 am #15990530
mirteM
Hey Adrey,
This is my server info (see attachment). It is a large host in Belgium (Combell).
I think it would indeed be good to fix it at the core as I found several others online with the same problem. I am however happy I found a workaround. I don't use automatic translations as we are required to know multiple languages ^^.
July 23, 2024 at 2:43 pm #15992959
Andrey
We need to investigate it further to find a suitable solution. Could you please share or reactivate the access so I can replicate the error, conduct further checks, and report to our team if necessary? Does the issue happen with a new product?
The following message is private.
July 24, 2024 at 8:49 am #15996978
mirteM
Would you mind using the copy you made for your tests? I have been working hard to clean up things here so I prefer to not change anything at this time.
