This topic contains 17 replies, has 0 voices.
Last updated by Kor 7 months, 2 weeks ago.
July 30, 2025 at 9:09 am #17281230
vitoG-4
yes, I saw, also live now is working.
If you remember you was configure Media (attachment), for solve the problem related that when I change the image to a blog post, it can't change to the others language.
Do you think is it possible to fix?
check this post, I changed the image and sync the others language.
the image in others language keep the old one.
July 31, 2025 at 6:31 pm #17286270
Thanks for your reply. Sorry, I don't have a solution for this, and I will need to escalate this further to our 2nd Tier Support for further investigation. I will come back to you once I've feedback.
August 5, 2025 at 4:43 pm #17297437
Thanks for your patience. Sorry, it looks like your staging site hidden link is no longer accessible, and our 2nd Tier Support is unable to proceed with the investigation. Could you please bring it back online so we can continue troubleshooting?
August 6, 2025 at 5:28 pm #17300603
Thanks for your reply. I've escalated this to our 2nd Tier Support and I will come back to you once I've feedback.
August 12, 2025 at 2:25 pm #17313952
Thanks for your patience. While checking on the staging site you provided, I noticed that the posts "Featured Images" are all broken as shown in the attached screenshot. Could you correct it so that our 2nd Tier Support can check on this?
August 12, 2025 at 6:30 pm #17314873
vitoG-4
Hello Kor,
ok done
August 13, 2025 at 12:59 am #17315330
Thanks for your reply. Could you let me know what changes you made? When I checked, the featured image on the translated posts is now showing the correct picture.
hidden link - English
hidden link - Spanish
August 13, 2025 at 9:59 am #17316340
vitoG-4
Hello Kor,
I was change it manually.
I again changed the image of the English post.
August 13, 2025 at 10:00 am #17316429
Thanks for your patience. Ok, I can see the issue now. Please leave it as it is and I will forward this to our 2nd Tier Support for further investigation.
August 14, 2025 at 4:22 pm #17321637
Thanks for your patience. I’ve received feedback from our 2nd Tier Support team.
We tested updating the featured image on the post you shared and re-translating it. Here’s what we found:
The featured image is stored correctly via the _thumbnail postmeta entry.
However, when translating the post, the new featured image isn’t being copied over to the translation.
When checking WPML > Settings, we noticed the entire Media Translation settings section is missing. It appears this section has been disabled by the Media Cloud plugin.
According to their plugin page, Media Cloud has its own WPML integration: hidden link. This integration is not developed or maintained by us, and it’s not a plugin we officially collaborate on. Since we have very few users with this plugin installed, we recommend asking the client to contact the plugin authors directly to find out why the WPML Media Settings are disabled. One of these missing settings is responsible for copying featured images to translations.
Alternatively, the client can manually update the featured images in each translation.
August 23, 2025 at 4:09 pm #17342112
vitoG-4
Hello Kor,
Let me check without MediaCloud activated.
Regards
August 23, 2025 at 4:10 pm #17342142
Ok, let me know how it goes.
August 23, 2025 at 4:41 pm #17342180
vitoG-4
Hello Kor,
I deactivated the Media Cloud plugin.
Can you please check if the Media Translation settings are now visible?
Can you send me a screenshot of that area?
August 25, 2025 at 3:26 pm #17345666
Thanks for your patience. We need to configure WPML > Settings > Post Types Translation > Media (attachment) as Translatable before the Media Translation settings below will appear. I need to recheck with our 2nd Tier Support and will come back to you as quickly as possible.
August 26, 2025 at 4:44 pm #17349143
vitoG-4
Hello Kor,
Ok perfect.
Also, remember that when we activate WPML > Settings > Post Types Translation > Media (attachment) as Translatable, the images on ProfileView become invisible.
regards
The topic ‘[Closed] Featured images not updated in translated posts’ is closed to new replies.
