Last updated by Kor 8 months, 1 week ago.
February 18, 2025 at 2:25 pm #16719564
jensK-16
Thanks a lot - worked fine :0)
There was another issue with featured products disappeared on frontpage translations
can we take that now or should I rather start a new thread?
February 18, 2025 at 2:41 pm #16719672
jensK-16
Did you get the picture I uploaded, otherwise it comes here
February 18, 2025 at 3:28 pm #16719829
WPML Supporter since 08/2022
Thanks for your reply.
Do you use any terms for your "Selected products" as shown in the attached screenshot? I'm referring to your terms you use for your Danish language Selected Products section. When I edited the Loop Grid in Danish language, the terms are not selected or showing.
You might want to manually adjust the query terms in "Loop Grid" > Query > Term here hidden link
Also, I edited the Loop Template here for the English language hidden link for a test. You might want to retranslate the texts to English language and I apologize for that.
Let me know how it goes.
February 19, 2025 at 8:42 am #16722758
jensK-16
Thank you for yours :0)
No we do not use that.
Actually it worked fine until I run a WPML routine trying to mend the problems from last thread. It was a fix suggested by your support earlier:
- Go to "WPML > Settings" and scroll down to the Media Translation section.
- Select the options shown in this screenshot and click on Start.
- Clear the caches from your site and browser and check again.
But it did not work this time, instead the featured products disappeared.
February 20, 2025 at 12:47 am #16727110
Thank you for getting back to me.
I've updated the source to "latest product" in Edit Loop Grid > Query as shown in the attached screenshot and your products are now visible. It seems there aren't any products marked as "featured" in English. Could you please review each English language product and ensure the ones you want to showcase in the featured section are configured correctly?
February 20, 2025 at 8:13 am #16727884
jensK-16
Thank you Kor, but there are still problems:
All languages looked fine, but when I tried to add a product to featured products in backend: it worked fine in main language, but everything disappeared in all other languages except for 1 product (Copy paper) AND the newly added featured product
I think this has nothing to do with elementor, the featured products are added in
backend > edit product.
February 21, 2025 at 2:40 am #16732010
I will have to investigate this further. You are correct, the translated products are already marked with "featured" but it is still not showing on the "Featured Products" Loop query.
February 21, 2025 at 5:05 pm #16734654
Thanks for your patience. Could you please backup and update all elementor plugins to the latest version? Also, update all WPML plugins too. hidden link
Let me know when you've done that and we'll recheck to see if the issue persists.
February 28, 2025 at 8:59 am #16759608
jensK-16
Hello again
Thank you for yours.
In fact all WPML plugins are already updated on live site. Elementor plugin have some critical warnings as to update so will take some time before we can update that. But 100% sure this has got nothing to do with Elementor, it worked perfectly until I did the WPML routine your colleague advised as described earlier.
February 28, 2025 at 9:45 am #16759943
Thank you for responding.
Once you've updated all plugins on your staging site, please inform me so I can recheck. If the issue persists post-update, I'll escalate it to our 2nd Tier Support. It's essential to have all plugins updated before proceeding with the escalation, and I appreciate your understanding.
March 5, 2025 at 7:57 am #16776826
jensK-16
Thank you really wonder why this should be necessary - everything worked perfect with current configuration until we followed your (WPML support's) advise from earlier which made the featured products crash.
We have now made a new backup: backup.grontkontor.dk with updated plugins, looking forward to finally see this problem solved.
March 6, 2025 at 6:49 am #16781134
Thanks for your patience. I have no solution for this and I will have to escalate this to our 2nd Tier Support for further investigation. I will come back to you once I've feedback.
March 6, 2025 at 8:56 am #16781823
jensK-16
OK thanks
March 7, 2025 at 8:50 am #16786661
Just letting you know that we're still looking into this and I will come back to you as quickly as possible.
March 7, 2025 at 10:13 am #16787342
jensK-16
OK thanks - really looking forward to see a solution
The topic ‘[Closed] featured products disappeared on frontpage translations’ is closed to new replies.
