The client is experiencing an issue where fields from Custom Fields for Variations are not showing up on the translated versions of their website. Although the fields have been translated via WooCommerce Multilingual, they are not editable in other languages and are missing on the front end.
We recommend the following steps to resolve the issue:
1. Navigate to Products-> Variation Field Groups.
2. Switch the language to English.
3. Edit the group.
4. Translate the field label manually.
5. Update the group.
6. Edit the product in the default language.
7. Click the
"Update"
button.
8. Update the English translation.
After completing these steps, the client should verify if the field labels are now correctly translated on the front end.
If this solution does not seem relevant to your situation, please do not hesitate to open a new support ticket with us.
Last updated by Osama Mersal 1 year, 6 months ago.
Assisted by: Osama Mersal.
December 7, 2023 at 8:19 am #15013825
petterH
I have used automatic translation with good results to three languages, but the fields from Custom Fields for Variations are not showing up on the translated sites. I have reached out to the developers at Iconic and they can confirm the issue on our site, but also confirmed that this is supposed to work and they have compatibility with WPML. They wanted me to reach out to you before diving in deeper. They suspected that maybe these strings have not synced properly.
You can see a lot of data fields on this product page in Swedish:
But they are missing here on the English version:
I can't edit the fields on the product on the other languages, they are locked, but I can see that the fields have been translated via Woocommerce Multilingual, but perhaps there has been some issue there with the strings? They seem to be part of a table structure in the translation and I don't know if that is supposed to be.
I just got an idea... Could it work if I switched from automatic translation now that the site has been translated and edit the fields manually when the lock is gone? But perhaps that has other downsides... Let me know if you need access to the site.
December 7, 2023 at 12:47 pm #15016751
petterH
Another issue, probably unrelated, I encountered now is that the language switcher does not show on the parent language front page. It does appear on the translated front pages, but the parent language is not listed. I use a different menu on sub-pages and there it works fine. But on the main menu on the front page it does not work. Do you know what could cause this issue?
New threads created by Osama Mersal and linked to this one are listed below:
https://wpml.org/forums/topic/menu-language-switcher-doesnt-appear-on-the-default-language-home-page/
December 10, 2023 at 9:53 am #15030711
Osama Mersal
WPML Supporter since 02/2020
1) First of all, sorry for the late reply; it was due to a higher workload. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
2) we try to keep one issue per ticket in our forum. Continuing with one ticket per issue helps supporters focus on one issue at once and enables other users to find solutions to their questions faster.
Therefore, I've split the other ticket and created a new ticket with this issue. (https://wpml.org/forums/topic/menu-language-switcher-doesnt-appear-on-the-default-language-home-page/)
Osama
December 10, 2023 at 2:17 pm #15031313
Osama Mersal
Thanks for the access details. Please check the following steps:
1- Go to Products-> Variation Field Groups
2- Switch the language to English
3- Edit the group
4- Translate the field label manually
5- Update the group
6- Edit the product in the default language
7- Click the "Update" button
8- Update the English translation
After the above steps, please check if the field labels are translated on the front end. (hidden link)
Osama
December 10, 2023 at 7:59 pm #15032033
petterH
It works! Great 🙂
How should I proceed to make it work on all products? Will I have to do it manually on every one? Or is it enough to do it manually on the field groups for Danish and Finnish too?
December 11, 2023 at 7:50 am #15033341
Osama Mersal
After translating the field groups manually in all languages, you need to update the products in the default language and update their translation using the WPML translation editor to translate the missing strings.
Osama
December 11, 2023 at 7:52 am #15033353
petterH
I see. Do you know if there is a way to batch update or will we have to do them one by one?
December 11, 2023 at 7:56 am #15033369
Osama Mersal
You can update them by page, but I'm not sure if that will be helpful in your case.
Please bulk update a page of products, re-translate them, and check if that fixes the issue. (Kindly check the attached screenshot)
Osama
December 11, 2023 at 8:49 am #15034083
petterH
Great, it seems it is all in place now!
Thanks a lot for your help 🙂
