You are trying to translate the footer on your website built with the Divi builder. While the footer appears translated in the editor, it does not display the translation on the live site.
If you're experiencing this issue, we recommend that you do not attempt to translate Divi Templates directly within the Divi Theme Builder. Instead, navigate to WPML > Translation Management > Dashboard. Use the dropdown filter at the top left to select the post type (Header Template, Body Template, Footer Template). Then, create a job for the footer template that you wish to translate and access the translation at WPML > Translation to translate the template using the WPML Translation Editor. This method ensures that the correct display condition is set for each template.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by nataliaS-11 5 months ago.
January 31, 2025 at 4:44 pm #16656774
nataliaS-11
I am trying to translate the footer on the website noisch.com, which is built with the Divi builder. The primary language is German, and the second language is Russian. All content has been translated, but the footer remains unchanged. URL: hidden link
The footer appears untranslated on the live site, although it shows as translated into Russian when editing the footer block.
Why is the footer not displaying the translation on the live site?
How can I ensure the footer translation is applied correctly?
January 31, 2025 at 5:54 pm #16656901
Marcel
before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
Did you use any of your installed Divi Extensions in the footer? There may be additional changes needed, such as an XML configuration, to ensure it appears translated.
Please let me know.
Marcel
January 31, 2025 at 7:08 pm #16657040
nataliaS-11
No, we do not use any additional Divi extensions in the footer.
February 1, 2025 at 5:20 pm #16658679
You can not translate Divi Templates directly inside the Divi Theme Builder.
To translate Divi Templates go to WPML > Translation Management > Dashboard.
Use the dropdown filter on the top left to select the post type:
- Header Template
- Body Template
- Footer Template
Now, create a job for the template that you would like to translate and access the translation at WPML > Translation to translate the template with the WPML Translation Editor.
This workflow will ensure that the correct display condition is set for each template.
February 2, 2025 at 9:34 am #16659704
nataliaS-11
Hello!
Everything worked out!
Thank you very much!
Have a great day!
Natalia
