The client has a bilingual website (English and French) and is facing an issue where the French version of a product is saving the English form instead of the French one. This issue may have arisen from forms being migrated from a previous website.
We recommend the following steps:
1. Ensure that you are using the Gravity Forms Multilingual addon to translate forms, rather than creating separate forms for each language.
2. Choose between using the WPML translation editor or the WordPress editor. If you prefer to manually add translated data and edit the second language product, select the WordPress editor from the default product and then manually set the correct form in the second language.
3. If you opt to use the WPML editor for translation, make sure to use the Gravity Forms Multilingual (GFML) addon and translate the forms correctly.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the issue persists, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
Last updated by 1 year, 2 months ago.
Assisted by: Dražen.
