You are trying to translate a website using Gutenberg blocks with Carbon Fields, but encounter an error when editing the page from the admin panel, and no blocks are displayed on the frontend.
We have identified that the issue might be related to the handling of complex or serialized fields by plugins similar to Carbon Fields. We recommend checking our errata on handling custom fields with complex keys stored as serialized arrays in WPML. You can find the temporary workaround here: Custom Fields with Complex Keys Are Stored as Serialized Arrays in WPML. Please try this solution and see if it resolves the issue.
If this solution does not apply to your case, or if it seems outdated, we highly recommend opening a new support ticket. Also, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. For further assistance, you can contact us directly through the WPML support forum.
Last updated by 9 months, 2 weeks ago.
Assisted by: Waqas Bin Hasan.
