If you're experiencing an issue where the header color on your translated site is not displaying properly,
We recommend following these steps:
1. Navigate to WPML >> Settings.
2. Scroll down to the "Custom Fields Translation" section.
3. Click on the "Show system fields" link.
4. Search for the "_woodmart_whb_header" field.
5. Set it to "Copy" and press the "Save" button.
6. Re-save the default language home page to apply the field settings to the translated home page.
After completing these steps, please clear your mobile browser cache and check if the issue is resolved.
If this solution does not apply because it might be outdated or not suitable for your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by 8 months, 3 weeks ago.
Assisted by: Noman.
