I have had some problem with the design is not showing on the second language on the dev site hidden link.
But that got fixed.
Now i cant see the header for products when im switching to english:
Here you have a catory page, so click on which product you want, and the menu will not show: hidden link
What do i need to do to show the header for produst?
Note that is conditional headers on this site.
Which means that the Motocross produts have a specific header, and the MTB products have a specific header as well.
How are the conditional headers created? are you using Kandence in order to create them?
I can see that another user has asked about the compatibility between their conditional headers but as I do not have an account I can't see their team's response.
I would also recommend reaching out to their team as well regarding this as they do know their code best and might have a quick solution.
