Supporter timezone: America/Los_Angeles (GMT-08:00)
Last updated by Bobby 3 months, 1 week ago.
Assisted by: Bobby.
August 26, 2024 at 3:49 pm #16105657
paul-adrianC
I bought WPML translator to translate my website from English to Romanian.
In the Blog section, the text appeared 2 times instead of having a herobanner and text.
A supporter from the WPML team tried to solve the problem by connecting to the website and replicating the site after I created a full website backup.
He mentioned that a text was added here: hidden link and I need to remove it. I did this, but the website looks exactly the same. The issue can be seen here: hidden link
The text in the Blog section appeared 2 times instead of having a herobanner and text. After following the supporter's instructions, the website looks exactly the same.
Why is the text in the Blog section appearing 2 times instead of having a herobanner and text?
What can be done to solve this error that has persisted for almost a month?
August 26, 2024 at 9:46 pm #16106888
Bobby
Timezone: America/Los_Angeles (GMT-08:00)
Hi Paul,
I have reviewed the previous thread you had with my colleague I would like to request temporary access (wp-admin and FTP) to your site to test the issue.
Thank you,
Bobby
September 2, 2024 at 8:51 pm #16133499
Bobby
The blog post uses theme options to display the styling.
Within the theme options at the top, you can use the language switcher and switch to RO, you will notice the warning from the theme developers.
"Please do not save the Theme Options while operating within any secondary languages. To translate specific values, please utilize the String Translator. More info."
Linking to this documentation:
The reason I am bringing this up is that your WPML license does not come with WPML String Translation, therefore there is a high chance the compatibility between Uncode and WPML is not as it should be.
Now regarding the header:
In the theme options (Under English) you will see that it's set to use a "Content Block" called "Header | Post Version one"
Navigate to Content Block -> Page 3 -> you will locate header | post version one, make sure to add the translation to it.
Once done check your blog again and let me know your results.
At the moment since there is no translation the theme options are not using a content block in Romanian thus the broken layout.
September 13, 2024 at 2:52 pm #16176415
paul-adrianC
Hello, as I am not developer and I don't know how to create websites, you need to explain me more.
I found "header | post version one", I am not sure what translation I need to add here. Can you please advise?
September 13, 2024 at 7:19 pm #16177607
Bobby
The most important fact to take from my reply is the following:
"There is no translation the theme options are not using a content block in Romanian thus the broken layout."
This explains why it's broken.
Therefore, we need to add the translation :).
To make this easier to understand I have recorded a loom video of myself working through this issue and trying to explain my steps as much as possible.
Please review:
Also, note that duplicating the content block helped resolve the issue 🙂
The topic ‘[Closed] Hello, I need help with my WPML translation plugin’ is closed to new replies.
