The client is experiencing an issue where the WPML plugin cannot connect to wpml.org, which is necessary for checking new releases and security updates. This problem is likely due to network or security settings that block outgoing communications.
We recommend following the steps in this guide to troubleshoot and resolve the connection issues. If the problem persists, it might be due to outdated information or a different issue not covered in the guide. In such cases, please check related known issues at https://wpml.org/known-issues/, verify you have the latest versions of themes and plugins, and consider opening a new support ticket for further assistance. You can do so at WPML support forum.
Last updated by 1 year, 9 months ago.
