Last updated by Dražen 1 year, 9 months ago.
Assisted by: Dražen.
August 2, 2023 at 10:44 am
muhammad-sohailR-2
I need small help related to ACF. I want to translate and select automatically but it is not working. Everytime I need to select it for translation
August 2, 2023 at 11:56 am
August 2, 2023 at 12:01 pm #14142031
Dražen
as agreed let's continue in the ticket.
Try to keep your test site in this minimal environment and not to much plugins activated.
1) Make sure your ACF field groups show in correct post type.
2) Translate the page and labels as per our docs:
- https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/#translating-labels
Make sure they are translated, and once you edit your 2nd language page you can see translated labels there.
3) Now, you probably have some Elementor widget where you choose to show ACF select field. Make sure to choose to show ACF label, and translate that template as per our Elementor documentation.
4) Or if you are using custom code you can check next docs:
- hidden link
Hope this helps.
Drazen
August 2, 2023 at 12:14 pm #14142071
muhammad-sohailR-2
I have implement the ACF now I can see "RED" there which is you have added. Let me know what next
August 2, 2023 at 12:22 pm #14142101
muhammad-sohailR-2
I think we fixed it, let me try one more thing
August 2, 2023 at 1:17 pm #14142655
Dražen
sure, make sure you are following my suggestion from the reply above.
Drazen
