Last updated by Lucas Vidal de Andrade 1 month, 4 weeks ago.
March 9, 2026 at 5:08 pm #17882874
Vincent Dagenais
We just installed WPML to translate our content.
We had a search and filter plugin, that has 2 filters setup.
Once WPML setup, and WPML WooCommerce plugins activate, I do not have access to the filters i used to have.
But in this filter listing, i do see 2 of ten being counted but they are not listed in the listing.
I did also check in wpml settings, -> troubleshooting, synchronize the search and filter posts taxonomies, i did also cleared WPML cache,
March 10, 2026 at 8:07 am #17884267
WPML Supporter since 11/2023
Hello there,
To better understand the issue, I need WPML's specific debug information. Please send me your debug information. The following link contains an explanation of how to do it. Please insert the information by clicking on the button above the text box, and not directly in the chat.
https://wpml.org/faq/provide-debug-information-faster-support/
Please do not input WPML debug's information directly as a regular message.
March 10, 2026 at 11:24 am #17884971
Vincent Dagenais
Here is the debug information
March 10, 2026 at 1:14 pm #17885677
Hey there,
Thanks for sharing.
I would like to look at this directly on your site. For this I would need temporary access (WP-Admin and FTP) to your site, preferably to a test/staging site where the problem has been replicated if possible.
I may need to replicate your website locally. To do this, I need to temporarily install a plugin called "Duplicator" or "All in One WP Migration" on your website. This will allow me to create a copy of your website and content. Once the issue is resolved, I will delete the local website. Let me know if this works for you.
IMPORTANT
Please make a backup copy of the site files and database before giving us access.
- If you do not see the wp-admin/FTP fields, this means your post and site login details are being made PUBLIC. DO NOT post your website details if you do not see the required wp-admin/FTP fields. If you do not, ask me to enable the private box. The private box looks like this:
March 10, 2026 at 2:25 pm #17885927
Vincent Dagenais
The problem only exists on the live site and not on our stage site.
If you want to do a backup with duplicator or all in one migration, the backup takes more then 3 hours and slows down the website.
Normally we do not give access to the admin panel eand ftp to external plugins maintainers.
Could we do this together so i can share my screen in a zoom call?
March 11, 2026 at 8:51 am #17887852
Hello there,
I understand your concern. Nonetheless, let me explain how I'll proceed in this case, perhaps that can work out for you.
I'll log in to the live website, install Duplicator Pro and create a copy excluding media and other large files. We usually can reach less than 1GB copies, which take only a few minutes to get built. Besides that, we won't make any changes on your website. Just install Duplicator, create the copy, and delete the plugin afterwards.
We unfortunately don't offer live support via calls, so having a local copy with the issue is the best way to proceed here. Let me know.
If that's ok for you, the form is private, so you can share access to the website safely. Let me know.
March 11, 2026 at 12:10 pm #17888488
Vincent Dagenais
Hi Lucas,
Since we couldn't wait for investiguation to take long time, and since this bug was only on the live site.
It was decided to create 2 new filters. And we were able to translate it.
And the problem still lives in the database but now our site works as normal.
Thanks for your time.
March 11, 2026 at 1:21 pm #17888883
Thank you. Let me know if you change your mind and want to proceed here.
