Can I hide products that are not translated, in both the original and in the secondary language?
You can't control how many products show up in the default language but you CAN control how many products are showing up in the translated version of the site.
So, in the secondary language, you should be able to display only the translated ones and in the source/original language, you can show all of them.
If you would like to accomplish that, please follow the steps below:
- Go to WPML -> Settings and click on "Post Types Translation"
- There you can select how "Products" will behave, select the option to "Translate" like in the screenshot here:
https://cdn.wpml.org/wp-content/uploads/2022/03/10823067-2429809_Screen_Shot_2018_06_22_at_17.02.26.png
Last updated by nikiforosB 3 years, 11 months ago.
Assisted by: Mihai Apetrei.
March 18, 2022 at 1:09 pm #10822669
nikiforosB
Hi, how are you? I need to show only the products that have translations.
I have 1000 products in the greek language and only 150 are translated to english. Is there a quick way to display only the 150 products in both languages?
March 18, 2022 at 1:53 pm #10823019
Laura
WPML Supporter since 05/2018
Hi, thanks for contacting us.
Unfortunately, there isn't a way to show only translated products in the default language. You should set them to private
March 18, 2022 at 1:55 pm #10823067
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
As my colleague mentioned above, you can't control how many products show up in the default language but you CAN control how many products are showing up in the translated version of the site.
So, in EN, you should be able to display only the translated ones and in Greek, you can show all of them.
- Go to WPML -> Settings and click on "Post Types Translation".
- There you can select how "Products" will behave, select the option to "Translate" like in the screenshot.
That should do exactly what you wanted.
Have a lovely rest of the day. 🙂
Mihai Apetrei
March 18, 2022 at 2:01 pm #10823189
nikiforosB
Well, I did have set to show only the translated products but I have to manualy disable the others in the native language. Thanks anyway.
