Last updated by Shekhar Bhandari 1 year, 4 months ago.
June 7, 2024 at 9:31 am
mcwI
How to export and import to another site all of our posts using WPML
June 7, 2024 at 11:46 am #15715959
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
I managed to import the categories following the below steps, you can check this video: hidden link
Can you try to use the same way and see if it helps.
June 7, 2024 at 12:57 pm #15716619
mcwI
I saw that it's okay now the categories. I tried to import now the Post, but all imported but the Categories are Uncagorized and all post imported are added to en , no in km
June 7, 2024 at 12:58 pm #15716620
mcwI
here the imported.
June 7, 2024 at 1:07 pm #15716668
Shekhar Bhandari
Hello there,
I checked the CSV files and I don't see the category mentioned there so it might be due to it the posts are on uncategorized, further, can you send me screenshots of your import settings so I can see what went wrong?
Look forward to your reply.
June 7, 2024 at 1:21 pm #15716708
mcwI
I Exported new csv, can you check? I selected all fields not only the standard fields for export.
I try re import and still not categorized and all imported in EN.
Attached also sa import settings in stg.
June 7, 2024 at 1:35 pm #15716821
Shekhar Bhandari
Hello there,
Please check this video and adjust accordingly: hidden link
Let me know if this helps.
June 7, 2024 at 2:03 pm #15716918
mcwI
Thank you Shekhar, now the importing is working. awesome!!
June 10, 2024 at 5:18 am #15720124
Shekhar Bhandari
Happy to know, you can mark this ticket as resolved if you don't need any further help.
The topic ‘[Closed] How to export and import to another site all of our posts using WPML’ is closed to new replies.
