The client is using WPML with the Husky Products Filter Professional and wants to maintain active filters when switching languages on their site. However, when switching languages, the URL changes and the active filters are lost.
According to the plugin author, this is a feature request and not a bug. It is recommended to contact the plugin author to see if they can address this feature request.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by Otto 5 months, 4 weeks ago.
Assisted by: Otto.
February 4, 2025 at 10:26 am #16666066
andreG-36
I am using WPML with the Husky Products Filter Professional on my site hidden link. I want to maintain active filters when switching languages on my site.
When I switch languages on a page with active filters, the URL changes from hidden link to hidden link, losing the active filters.
How can I maintain active filters when switching languages using WPML?
February 4, 2025 at 2:17 pm #16667250
Otto
WPML Supporter since 09/2015
As far as I can see you need to keep the filter parameters when switching languages.
You can achieve that by following these steps:
Preserve URL Arguments When Switching Languages
I'm not sure it will work once you translate the categories because the parameters will need to be preserved and translated. In any case, it's worth giving it a try 🙂
It may be possible that this scenario was not considered because it is not a common use case that a user switches when he already started to filter in one language.
Please let me know how it goes, and we will move forward from there, a proper solution may need some compatibility work.
Best Regards,
Otto
February 5, 2025 at 11:54 am #16670839
andreG-36
I implement the solution you sent but it didn't work. By keeping the parameters in the url you also keep the values. For example: hidden link keeping the "pa_categoria-de-loja-2" also keeps the "noivado".
The url in English should be as:
The strange thing is that with the same plugins on the old website it works.
Thanks you
February 5, 2025 at 4:25 pm #16672368
Otto
Thanks, yes, I suspected that may be the case 🙁
Weirdly, it's working on the other website.. but it gives us hope :). It may be a compatibility or a configuration problem, so we need to see the problem from scratch in a minimal environment.
I created a fresh WP install to see the problem in a minimal environment.
Can you please help me set it up and reproduce the issue? I installed WooCommerce, WPML, and WCML. Can you please install and configure the Husky Products Filter Professional plugin?
You can access the site by following this link:
Thanks for your cooperation!
Best Regards,
Otto
February 5, 2025 at 4:31 pm #16672379
Otto
Meanwhile I found this similar ticket:
https://wpml.org/forums/topic/issue-with-attribute-slug-in-filter-url-2/
Hi there!We have reported the issue to the author and they have answered that they will send it to the dev team.It looks more a feature request than a bug.We recommend you also to contact them as well reporting the bug.
I suggest you contact the plugin author to see if they tackle the feature request.
