Unfortunately, our AI support agent could not properly identify the plugin that you are using for product add-ons. Currently, WPML is fully compatible with the WooCommerce Product Add-ons, developed by WooCommerce itself. Apparently, you are using a different plugin, named hidden link, developed by Acowebs.
We do not know about the compatibility status for that plugin with WPML - we do not have records for it, and we have not tested it. However, the plugin author has some documentation about it, hidden link. I would suggest that you check it, and eventually consult with their support team about their compatibility policy.
Regards.
The topic ‘[Closed] I am having an issue with WPML and my Product Add-Ons plugin.’ is closed to new replies.
