The client is using Advanced Custom Fields (ACF) with WPML and has set up the Advanced Custom Fields Multilingual. However, the field choices are not being translated in the frontend despite translating the labels in WPML>>String Translation. The features section with bullet points is not translated across all languages.
We recommended using the
get_field_object
function instead of
get_field
to fetch the field data correctly. This change should allow the field choices to display the translated values.
Here is the modified code snippet to implement in the functions.php file of the child theme:
// Create shortcodes for individual fields without titles
function generate_individual_field_shortcodes_no_title() {
    // List of fields to create shortcodes for
    $fields = [
        'living_area',
        'views',
        'laundry',
        'bathroom',
        'kitchen_and_dining',
        'bedroom',
        'media_and_entertainment',
        'miscellaneous',
        'home_safety',
        'outdoor_spaces',
        'family-friendly',
        'parking_and_facilities',
        'languages_spoken',
        'nearby',
        'house_rules',
        'cancellation_prepayment',
        'refundable_damage_deposit',
        'payment_methods'
    foreach ($fields as $field) {
        // Dynamically generate shortcode callback for each field
        add_shortcode($field . '_list', function() use ($field) {
            ob_start(); // Start output buffering
            $fields = get_field_object($field); //Get field data
            $options = $fields['value'];
            // Display labels.
            if( $options ): ?>
            <ul>
                <?php foreach( $options as $option ): ?>
                    <li><?php echo $fields['choices'][$option]; ?></li>
                <?php endforeach; ?>
            </ul>
            <?php endif;
            return ob_get_clean(); // Return the output and end buffering
add_action('init', 'generate_individual_field_shortcodes_no_title');
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
Last updated by vladimirM-19 8 months ago.
Assisted by: Bigul.
November 28, 2024 at 7:14 pm #16456764
vladimirM-19
I am using ACF and I setup the Advanced Custom Fields Multilingual, but my field choices are not getting translated. I translated the labels in WPML, but the fields in languages are not getting updated. Link to a page where the issue can be seen: hidden link
Features section with bullet points should be translated across all languages. I get the values, but they are not translated across languages.
Why are my field choices not getting translated in ACF with WPML?
How can I ensure that the fields are updated in all languages?
November 29, 2024 at 12:45 pm #16459562
Dražen
Thanks for contacting us.
Can you please explain how are you showing ACF choice on your website, using PHP code or some plugin? Do you choose to show ACF value or label from field settings?
Does it work if you try using the default ACF code to show the label on the front?
- hidden link
Let us know how it goes.
Drazen
November 29, 2024 at 3:03 pm #16460231
vladimirM-19
Hi Drazen,
Yes, It is implemented through Short code, and it is presented on the frontend. In the image you can see the values, but they are just not translated. So english is in all languages
December 1, 2024 at 5:12 pm #16463497
Bigul
WPML Supporter since 01/2013
Thank you for the updates. Please share more details about the following for a better understanding. It would be great if you could share a couple of screenshots.
Also, please fill in the private details fields after a full site backup. I would like to access the admin area of your site for further checking. Refer to the following links for more details about our private information sharing policies.
Bigul
December 3, 2024 at 5:57 pm #16473289
Bigul
Thank you for the details and login information. This requires further testing. Do you have a staging/dev site, a clone copy of the live site? It will help us to troubleshoot the bug without affecting the live site.
If not, please allow me to make a duplicator copy of your site using the Duplicator plugin (https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server.
Bigul
December 3, 2024 at 6:46 pm #16473451
vladimirM-19
Hi Bigul,
I have a backup made, but feel free to setup Duplicator.
Vladimir
December 4, 2024 at 4:23 pm #16478012
Bigul
Hi Vladimir,
Thank you for the permission. I made a copy of the site, we will debug it further locally and get back to you as soon as possible. Please wait.
Bigul
December 9, 2024 at 3:58 am #16490826
Bigul
Hi Vladimir,
Sorry for the late response, because of the weekend. After using the *get_field_object* function instead of *get_field*, I got the expected results in my local copy. Refer to this document and the attached images for more details - hidden link
Please try with the following code after a full site backup and let us know your feedback.
    $fields = [
        'living_area',
        'views',
        'laundry',
        'bathroom',
        'bedroom',
        'miscellaneous',
        'home_safety',
        'outdoor_spaces',
        'family-friendly',
        'languages_spoken',
        'nearby',
        'house_rules',
        'payment_methods'
            // Display labels.
            if( $options ): ?>
            <ul>
            </ul>
            <?php endif;
Bigul
December 9, 2024 at 1:26 pm #16493138
vladimirM-19
Hi Bigul, amazing, resolved. Thank you
