This topic contains 55 replies, has 0 voices.
Last updated by Dražen 3 months, 3 weeks ago.
Assisted by: Dražen.
May 26, 2025 at 6:32 am #17070953 | |
sergeyZ-8 |
May 26, 2025 at 7:23 am #17071171 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello, please test if the issue still happen when only WPML plugins enabled and when using WP default theme. Let us know how it goes. Regadrs, |
May 26, 2025 at 7:57 am #17071392 | |
sergeyZ-8 |
hidden link |
May 26, 2025 at 8:01 am #17071431 | |
sergeyZ-8 |
i installed theme 24 and i get the same error |
May 26, 2025 at 8:05 am #17071455 | |
sergeyZ-8 |
How long should I wait for an answer? |
May 26, 2025 at 9:07 am #17071906 | |
Dražen Supporter
Hello, thanks I have checked and can see issue even with only WPML plugins. Can you please update WPML plugins to latest, or let me know if it okay and I can also update and check further. Regards, |
May 26, 2025 at 9:45 am #17072236 | |
sergeyZ-8 |
i update |
May 26, 2025 at 9:46 am #17072238 | |
sergeyZ-8 |
can you solve the problem? how long should theme 24 be on |
May 26, 2025 at 10:06 am #17072430 | |
Dražen Supporter
Hello, I checked further but I could not find the fix. Is it okay to take a copy of your website to check the issue further? Regards, |
May 26, 2025 at 10:54 am #17072683 | |
sergeyZ-8 |
How do I make a copy of you? |
May 26, 2025 at 10:58 am #17072779 | |
sergeyZ-8 |
Can we go to chat to resolve the issue faster? |
May 26, 2025 at 11:03 am #17072826 | |
Dražen Supporter
Hello, it is not an issue that can be solved in chat, as you can see it takes time to debug and check etc, so it needs to be and continue in this ticket. You can provide a copy using Duplicator as described or let me know if I have your permission and I will create one myself. - https://wpml.org/fr/faq/provide-supporters-copy-site/ Regards, |
May 26, 2025 at 11:06 am #17072832 | |
sergeyZ-8 |
you can create it yourself |
May 26, 2025 at 11:16 am #17072908 | |
sergeyZ-8 |
you are create backup, i can switch theme? |
May 26, 2025 at 11:29 am #17072969 | |
Dražen Supporter
Hello, I have created a copy and checked on localhost and it works fine, so it is mostly likely some issue / bug with current setup / server. Can you provide us staging site with FTP access, so we can further Check. We might need to be able to take 1-2 days and check and disable plugins / themes and etc. Video of it working fine in local: If you wish you can also try on another server / check server log / debug log for any clues what might be the problem. Regards, |
