Last updated by Bobby 1 year, 10 months ago.
Assisted by: Bobby.
June 28, 2024 at 5:05 am #15848826
sichaphatF
translate manually by creating new website but it show something missing in .htcaccess file / I use elementor to develop the website. As a part that I am not know about coding. Please help me to fix it. Thank you
the attatch file like this : hidden link
Hope to hear from you soon
<b>Symptoms: </b>
<b>Questions: </b>
June 28, 2024 at 5:21 am #15849013
Bobby
WPML Supporter since 04/2015
What do you mean by "translate manually by creating new website" , please provide some more details to better understand.
Regarding the warning you received, it is from Elementor and it stating that your .htaccess file might be missing.
Go to your CPANEL and access your file manager then review your directory, you should have a file called .htaccess and this is the content that should be within it per WordPress.
https://developer.wordpress.org/advanced-administration/server/web-server/httpd/
If you are not comfortable with making these changes or not sure where to look I suggest contacting your hosting provider's support as they should be able to resolve this from their side.
June 28, 2024 at 9:09 am #15850654
sichaphatF
"translate manually by creating new website" mean I do English page and Thai page.
I will try to check thank you so much.
June 28, 2024 at 6:13 pm #15853714
Bobby
Ah OK, yes that should not be a problem.
The topic ‘[Closed] I have a problem with .htaccess file , how can i solve?’ is closed to new replies.
