Last updated by Alejandro 1 week, 6 days ago.
August 1, 2025 at 3:46 am #17286969
steveW-16
I have created the homepage for English and Spanish using WPML on my site hidden link. I am trying to ensure that both language versions appear in the sitemap.
The Spanish homepage is not appearing in the sitemap despite trying all settings.
Why is the Spanish homepage not appearing in the sitemap?
August 1, 2025 at 3:55 am #17286984
steveW-16
Spanish is not showing up on sitemap page.
August 1, 2025 at 10:29 am #17287916
Alejandro
WPML Supporter since 02/2018
I'll help you get started while a supporter takes your case.
1) You need to meet our minimum requirements or some things won't work as expected.
You need to increase your memory, preferably to 256M in order to get things working correctly: https://developer.wordpress.org/advanced-administration/wordpress/wp-config/#increasing-memory-allocated-to-php
2) What you're showing is not the standard sitemap of a site, how are you creating it? is it just a page with links on it? If so, it depends how the page was created. if they are just links, you may want to retranslate the page from WPML > Translation Management and then send it for translation there.
However, Knowing how that page was created is likely key to understand how we can solve the problem.
