Last updated by adrianA-18 1 day, 3 hours ago.
Assisted by: Noman.
July 14, 2025 at 3:00 pm #17234539
adrianA-18
I have translated the menu into English, French, and Italian using WPML. The site I need help with is hidden link.
The menu still appears in Spanish despite being translated into English, French, and Italian.
Why does the menu still appear in Spanish after translation?
How can I ensure the menu displays correctly in English, French, and Italian?
July 15, 2025 at 9:17 am #17236958
Noman
WPML Supporter since 06/2016
Thank you for contacting WPML Support. I visited your website, and I noticed that menu text is added from Appearance >> Menus using menu Custom Links. To translate the menu items correctly, please follow the below steps:
1. Take a backup of your site first for safety reasons.
2. Go to WPML >> WP Menu Sync page and press the Sync button.
3. Select all the menu items and press the “Apply Changes” button.
4. Please make sure to complete the translation of custom menu links from WPML >> String Translation using the link on WP Menu Sync page as you can see in the attached screenshot.
5. After translating the custom links, go to WPML >> WP Menu Sync page and press the Sync button again.
If the issue persists, please try to follow the below procedure:
1. Go to the Appearance >> Menus page.
2. Choose the header/Main menu.
3. Click on the secondary language icon to open up the secondary language menu.
4. Please make sure the menu items are translated correctly in secondary language and press the Save Menu button.
Here is a doc for more details about menu translation:
https://wpml.org/documentation/getting-started-guide/translating-menus/
Thank you
July 15, 2025 at 10:14 am #17237188
adrianA-18
Hello Noman,
Thank you for your message,
I have followed all the steps you have mentioned but in point 4, I didn't find the strings as your screenshot: Main Menu English, Main Menu French... I see only "Menu". *I send you a screenshot. Only appears "Menu"
4. "Please make sure to complete the translation of custom menu links from WPML >> String Translation using the link on WP Menu Sync page as you can see in the attached screenshot".
When I tried to follow the other steps:
I realized that the Menu in English there's nothing I send you a screnshot but when I go to Spanish Menu I see below "Add Menu items" there are 5 menus in english, french and italian but only three in Spanish. It seems that when I do this Im duplicating the menus.
I see that I have a warning that automatic string registration is deactivated I don't know if this has anything to do with.
Thank you very much for your help,
July 15, 2025 at 4:12 pm #17238958
Noman
Thanks for trying the above steps.
Please go to the WPML >> WP Menu Sync page and click on the “Menu” link and it will redirect you to the String Translation page, please make sure to complete the translation of all those menu items labels/URL’s in all languages.
After completing translation, please return back to WPML >> WP Menu Sync page and press the Sync button again and see if this resolves the issue.
If the issue persists, please provide temporary access (WP-Admin and FTP Login info) to your site (preferably staging site), so that I can look into your setup and debug the issue.
✙ I would need your permission to deactivate and reactivate Plugins and the Theme and to change configurations on the site. This is also a reason the backup is essential.
Thank you
July 17, 2025 at 8:43 am #17244456
Noman
Thanks for providing the login details. I tried syncing the menu and also used the troubleshooting steps under WPML >> Support >> Troubleshooting, but that didn’t work. So, I followed these steps:
1. Went to Appearance >> Menus.
2. Choose the Primary Menu in Spanish language.
3. Clicked on the secondary language icons to open their translated menus.
4. Deleted the translated menus from the secondary languages.
5. Synced the menu again via WPML >> WP Menu Sync.
This resolved the issue. Could you please check and confirm?
Thank you for your cooperation.
July 18, 2025 at 2:07 pm #17250688
adrianA-18
Thank you Noman, now the issue is resolved,
Thank you so much,
