Last updated by Dražen 5 months, 2 weeks ago.
Assisted by: Waqas Bin Hasan.
March 3, 2025 at 5:15 pm #16770151
jacintheB-2
I am trying to edit the footer which is currently only in French across the website, including the English version. I am also attempting to translate the website into Spanish. I have been translating by skipping WPML because it is not working. If I can't resolve this, I may have to stop using WPML. Link to a page where the issue can be seen: Allover mathemalchemy.org
I keep getting a pop-up saying 'Jobs could not be loaded' in Translation Management. I expected to see jobs, but instead, I got the pop-up.
Why am I seeing a pop-up saying 'Jobs could not be loaded'?
How can I edit the footer to display in English as well?
What steps can I take to successfully translate the website into Spanish using WPML?
March 4, 2025 at 8:48 am #16772009
Waqas Bin Hasan
WPML Supporter since 05/2014
Before proceeding further, can you please try the following?
IMPORTANT: Please take full backup of your website and database beforehand.
1) First of all unregister and register WPML:
- In your website, go to Plugins -> Add New -> Commercial.
- Unregister WPML by clicking the unregister link.
- Then go to https://wpml.org/account/sites/.
- Delete the existing site key.
- Create a new site key.
- Then go back to Plugins -> Add New -> Commercial on your website.
- Click the register link and use the new sitekey (created above) to register.
2) Then go to WPML > Support > Installer Log and make sure the subscription is working correctly.
3) Then go to WPML -> Support -> Troubleshooting and Press the following buttons:
- "Clear the cache in WPML"
- "Remove ghost entries from the translation tables"
- "Fix element_type collation"
- "Set language information"
- "Fix post type assignment for translations"
4) Open a new tab but leave this page open.
5) In the new tab, go to WPML > Translation Management and make sure you're set as a translator and as a translation management (you will be set automatically as a translation editor if you are an Admin)
6) Go to Users > All users and make sure all the admin users and translators have on their profile: name, last name, mail and public display option correctly setup (if one is missing, fill it out).
7) Return to the other tab with WPML > Support > Troubleshooting, page open. try to click the 2 options about "ATE" (sync ATE local jobs... the other option might not be on your site, it only appears if you have an issue related to that problem but it has the word "ATE" in it so you can easily spot it).
8) Try to go to WPML > Translation Management, send the job for translation and let's see if it works this time.
I hope this 'll help fixing the said issue, however, if it doesn't then we may need to interact directly with the database. Please let me know and I'll try my best to help you further on the matter.
Regards.
March 8, 2025 at 8:45 pm #16791997
jacintheB-2
I have followed every step (thank you, it was quite clear). Unfortunately, I still get the "Jobs could not be loaded" (see screen capture attached).
Only steps I was not 100% sure about were those 2 :
FIRST- 2) Then go to WPML > Support > Installer Log and make sure the subscription is working correctly.
I did not see any error or mentioned about improper setup, but was not sure what I was suppose to see if it was or was not working correctly.
SECOND- 6) Go to Users > All users and make sure all the admin users and translators have on their profile: name, last name, mail and public display option correctly setup (if one is missing, fill it out).
My name, first name, public display parameters were not accessible via the "Users", but via WordPress.com/me
I made sure it was ok on that platform. All other translators were ok.
Thank you in advance for your support.
March 10, 2025 at 7:17 am #16794550
Waqas Bin Hasan
Thank you for the updates.
I need to take a closer look at your site. So I request temporary access (WP-Admin and FTP), preferably to a test site where the problem has been replicated.
Your next answer will be private, to share this information safely.
Also provide detailed steps to reproduce the issue and links to pages in the admin and on the frontend.
IMPORTANT: Please take a complete backup of the site to avoid data loss. I may need to activate/deactivate plugins also.
P.S.: If you don't see the section for providing access information, do not write in the message box or the information may appear as public.
March 14, 2025 at 12:44 am #16814042
jacintheB-2
Hello Waqas,
I'm creating a test site so you can test it - could you kindly leave this ticket open and allow my next answer to be private?
Thank you in advance!
March 14, 2025 at 12:45 am #16814043
jacintheB-2
I should be able to have everything set up by next Monday.
March 14, 2025 at 8:08 am #16814925
Waqas Bin Hasan
Sure no problem, please take your time.
I've set your next reply as private again to provide the access. Please reply when you're ready.
March 24, 2025 at 1:19 am #16849479
jacintheB-2
I'm sorry for my late reply. I found somebody to help me - I should get back to you on Wednesday on the latest. Kindly make my next answer private!
March 24, 2025 at 9:11 am #16850443
Waqas Bin Hasan
No problem, please take your time.
I've set your next reply as private.
March 30, 2025 at 11:29 pm #16877201
jacintheB-2
I withdraw the password because my answer didn't appear private. Can you confirm the information given at #16877200 was really private? If so, kindly make my next answer also private and I'll send you the password.
Or should I send it to you via email? If so, you could maybe send me your email to my email address (which is attached to this account).
March 31, 2025 at 10:15 am #16878527
Dražen
Hello Jacinthe,
Waqas is OFF on vacation, so I will help with this issue and check why you get jobs not loaded. Then if any other issue we will check it out in another new ticket, to keep things organized.
I have set that reply private now and have enabled, private your next reply.
Drazen
The topic ‘[Closed] I keep on having a pop-up saying “Jobs could not be loaded” in Translation Management. I have alre…’ is closed to new replies.
