You are using WPML with Elementor to create a bilingual website and have created separate templates for English and Arabic. However, the Arabic templates are not displaying correctly on the Arabic side of the website, and instead, the English templates are showing.
We recommend installing the WPML String Translation plugin if you haven't already. This plugin is essential for translating Elementor templates. Once installed, it should resolve the issue of the Arabic templates not displaying correctly. You can find more information about this plugin and its installation at https://wpml.org/documentation/plugins-compatibility/elementor/#required-plugins.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket at WPML support forum.
Last updated by 1 year, 1 month ago.
Assisted by: Osama Mersal.
