Last updated by Kor 1 year, 3 months ago.
January 9, 2025 at 12:33 pm #16577715
gazmendS
I am trying to manually edit translations for my website content using WPML. Specifically, I want to make changes to translated text directly (e.g., page content, buttons, or metadata) without relying solely on the Advanced Translation Editor.
Some translations appear locked or uneditable, and in some cases, the translation editor shows a blank screen, preventing any progress.
How can I enable manual editing for translations that appear locked or uneditable?
What should I do when the translation editor shows a blank screen?
January 9, 2025 at 12:50 pm #16577803
gazmendS
"I am trying to manually edit translations for my website content using WPML. Specifically:
Some translations appear locked or uneditable, and I need to understand how to enable manual editing.
In some cases, the translation editor shows a blank screen, preventing any progress.
I would like to either edit translations manually or resolve the issues with the editor to make the necessary adjustments."
January 9, 2025 at 1:09 pm #16577902
gazmendS
As you can see from the uploads, when i click on the words on the right(the german ones) the site just turns white, and there are 2 errors in the console(dont know if they are related to the problem) but its not working to edit.
January 10, 2025 at 5:31 am #16580274
Thanks for contacting us.
I've checked your screenshots and I can see the issue you had there. The advanced translation editor page should not display white when you try to translate the content. Could you copy and paste the URL here so that I can check the translation ID on our end?
Also, editing the contents manually can only be done if you turn off the "advanced Translation editor" as explained here https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/
January 10, 2025 at 7:14 am #16580378
gazmendS
Here it is
January 10, 2025 at 8:10 am #16580495
gazmendS
I have sent you the link you requested. Can you assist with resolving this issue?
January 10, 2025 at 10:12 am #16581256
Thanks for your reply.
I didn't see any issues when I checked your translations. Refer to this screen recording hidden link .
Probably some 3rd party plugin conflicting with WPML and I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
The topic ‘[Closed] “I need help with manually editing translations in WPML. Currently, I am unable to make manual chan…’ is closed to new replies.
