The client was experiencing an issue where the 'Place order' button text in the checkout section of their website remained in English despite being translated into Serbian.
We recommended updating the WPML and String Translation plugins to the latest version. After the update, the translation for the 'Place order' button should display correctly in Serbian.
If you're experiencing a similar issue, we recommend you try updating your WPML and String Translation plugins to the latest versions. If the problem persists, it might be due to an outdated solution or because it's not applicable to your case. In such instances, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket with us.
This topic contains 1 replies, has 2 voices.
Last updated by Long Nguyen 1 year, 2 months ago.
Assisted by: Long Nguyen.
April 8, 2024 at 7:22 am
sreckoA
Long hi, im experiencing some issues with my translated string. Website is basdomace.rs and when you finish the order in checkout part...Place oreder stays in English, and its translated. You can even see translation and then its back to place order
April 8, 2024 at 8:07 am
April 8, 2024 at 9:00 am #15493206
Long Nguyen
WPML Supporter since 02/2022
After updating plugins WPML and String Translation on your site to the new version, the translation string is displayed correctly in the Serbian language. Let me know if it works on your end.
April 9, 2024 at 9:15 am #15497696
sreckoA
Great! Long thank you for your help! Case closed.
