You are updating posts and adding new content but have noticed that images with URLs are no longer visible in the Advanced Translation Editor (ATE) for URL translation. Although images are translated in Media Translation, their URLs remain in the primary language, and this issue does not affect older posts.
We recommend adding the following XML configuration to your WPML settings under the Custom XML tab to address this issue:
<wpml-config><br /><elementor-widgets><br /><widget name="image"><br /><fields><br /><field>image>alt</field><br /><field>link>url</field><br /></fields><br /></widget><br /></elementor-widgets><br /></wpml-config>
After applying this XML, you should be able to see the URLs correctly in the ATE. Please complete the translation of the post and verify if the URLs are translated correctly on the front end.
If this solution does not resolve your issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Osama Mersal 8 months ago.
Assisted by: Osama Mersal.
April 10, 2025 at 2:10 pm #16919060
justinK-16
Added the XML - now all URLs appear in the ATE (already translated - as they should be from past translation).
So do you think that the issue is a conflict with Elementor and WPML, since the URLs used to appear in the ATE (without XML registration)?
As I have now activated all plugins.
Recently, I updated WPML and Elementor and Elementor Pro (maybe a week before I spotted the issue).
One last thing - I originally brought this up at the same time.
The image in the sidebar slider also used to translate both the image AND the URL.
Can you provide the XML to add for this (although it may be a slightly more complicated issue)
This sidebar is in a separate blog post template
The Image appears as it has been added to the Sidebar with a Custom HTML widget, and a plugin called Widget Context is configured to tell it on which post we want it to appear.
I have then added the script to String Translation (after sourcing it from Admin Texts).
Then I string translation, I translated the URL, Image Source, and the ALT.
This is all still translated correctly in string translation when I check it.
However, I believe this is part of the same issue as I discovered it no longer translates at the same time as the other images.
Is it possible to also register this in XML, or is it different as it is being handled in String Translation?
It NEVER previously appeared in the ATE and I actually don't need it to. I was happy with it automatically translating in the background.
New threads created by Osama Mersal and linked to this one are listed below:
https://wpml.org/forums/topic/translate-sidebar-images/
April 10, 2025 at 2:11 pm #16919065
justinK-16
sorry i forgot to attach the image
April 10, 2025 at 2:27 pm #16919202
Osama Mersal
WPML Supporter since 02/2020
It seems like a different issue. I've split it and created a new ticket with this issue.
We try to keep one issue per ticket in our forum. Continuing with one ticket per issue helps supporters focus on one issue at a time and enables other users to find solutions to their questions faster.
Osama
April 10, 2025 at 2:37 pm #16919255
justinK-16
Ok, thanks for your help with this
April 10, 2025 at 2:57 pm #16919322
Osama Mersal
You are more than welcome! 🙂 Please don't hesitate to open a new ticket if you face any other issues. We are always happy to help you.
Have a great day!
Osama
