This topic contains 21 replies, has 3 voices.
Last updated by Shekhar Bhandari 1 year, 9 months ago.
September 27, 2023 at 12:38 pm #14474177 | |
Shekhar Bhandari WPML Supporter since 03/2015
Languages: English (English ) Timezone: Asia/Kathmandu (GMT+05:45) |
Hello there, Thank you for the explanation. Can you provide me with the CSV files for the import? Also there are around 30+ import, would you mind letting me know the id you used for default language import and for secondary language import. Look forward to your reply. Thanks |
September 27, 2023 at 3:22 pm #14475521 | |
jevgenijsG |
Dear Shekhar, Please find test csv files for default and secondary language here: hidden link I have attached screenshot determining default lang import and secondary language files. Kind regards, |
September 28, 2023 at 5:12 am #14478331 | |
Hello there, The files have been deleted as of now. Also, I see all the import language has been set as English, you should select the import language accordingly, on the provided screenshot you should select the content language to be LV if you want to import on LV languages. Once I have the CSV files, I will import them to see if there are any issues. Thanks |
September 29, 2023 at 10:50 am #14487193 | |
jevgenijsG |
Dear Shekhar, Please find link to files below: 1.I have tried now to to add csv for 'lv' language as default(unique id was selected as product ID, same as before) Still can't see eng text for product. Please kindly assist through the process. Kind regards, |
September 29, 2023 at 3:04 pm #14488437 | |
Hello there, Please view the following two videos, I created two due to limitations on my recording software. In the video, you can see how the translations are imported without any issues. You will see taxonomies (categories) not created, I guess this is due to the fact that the category doesn't exist on translations, please translate the category first and run the import and it should work without any issues. First: hidden link Look forward to your reply. Thanks |
October 4, 2023 at 11:03 am #14512179 | |
jevgenijsG |
Dear Shekhar, Thank you very much for informative video. A things pop up: 1. problem with import(Screenshot 2023-10-04 at 13.37.18.png): 2 point(Screenshot 2023-10-04 at 13.49.13): -- 1. How can we avoid creating duplicate product and add ENG translation for original product(LV lang.)? I look forward to hearing from you soon. Kind regards, |
October 4, 2023 at 12:18 pm #14512877 | |
Hello there, 1. How can we avoid creating duplicate product and add ENG translation for original product(LV lang.)? Once you exported the products csv you can delete the products so it will not create any duplicate products, for new product imports, you can enable the check to update if already exists on the import settings, you have this settings on step 4. 2. How to copy product attributes from original product into ENG product + add "short description" and "content" from ENG translation? You will need to add the content to csv and import accordingly, or add it manually afterwards editing the product, there is no such settings in import to copy the content from original at the moment. Let me know if this helps. Thanks |
