 dimitriosD
I'm trying to translate my eshop using WPML. I'm encountering an issue with the Improved Product Options for WooCommerce plugin.
Colors are shown as buttons with text instead of as colors.
Why are colors displayed as text buttons instead of colors when using WPML with Improved Product Options for WooCommerce?
 Bruno Kos
Languages:
English (English )
German (Deutsch )
French (Français )
Timezone:
Europe/Zagreb (GMT+02:00)
On this sandbox:
Can you do the following:
- Install **Improved Product Options for WooCommerce**
- Set up one category with a color
- Create a product using this color (and translate it) to demonstrate the issue
I will then escalate the case to our compatibility team.
 dimitriosD
Hello again.
I did everything you ask and you can have a look
thank you!
 Bruno Kos
Languages:
English (English )
German (Deutsch )
French (Français )
Timezone:
This has been escalated to our Compatibility team and may take some debugging time, I'll get back to you as soon as I have any news or questions for you.
 Bruno Kos
Languages:
English (English )
German (Deutsch )
French (Français )
Timezone:
Can you please try the following:
1. Navigate to **WooCommerce > Settings > Improved Options > Product Options tab** in your WordPress dashboard.
2. Use the **language selector** located in the **top admin bar** to switch the language to other language.
3. Go to **Products > Attributes** and add the **Color attribute**. Once added, click "Configure terms" to add specific color terms (e.g., Red, Blue, Green).
Does it work?
As for the technical details, all customizations are stored in the option: **`svx_settings_improved_options`**.
For each language, a language prefix is added to the option. For example: **`wc_ivpa_attribute_customization_fr`** (for French e.g.).
This behavior is defined in the plugin’s `ivpa-frontend.php` file, specifically in this line:
$curr_customizations = SevenVXGet()->get_option( 'wc_ivpa_attribute_customization_' . $curr_language, 'improved_options', '' );
We recommend asking the plugin developers to join our https://wpml.org/documentation/support/go-global-program/. This program provides dedicated guidance to help developers make their plugins fully compatible with WPML.
We’d be happy to assist them throughout the process.
