Last updated by Kor 2 months, 1 week ago.
February 4, 2026 at 1:50 pm #17791915
vadimP
We are using "Advanced Product Fields Pro for WooCommerce" plugin for our products and would like to use WPML automatic translation to translate all product fields added via this plugin.
Currently if we try doing this through Translation Dashboard, it says that the product field group is already translated.
If you check the WPML advanced translation editor, it only shows the title as the translatable field, nothing else.
Do we need to adjust any settings so that all fields inside the "Product Fields" can be either automatically translated or at least visible in the translation editor?
February 4, 2026 at 5:31 pm #17793602
Thanks for your patience. I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
February 9, 2026 at 2:07 pm #17805370
Thanks for your reply. I've checked and I noticed that you've configured the "acf-field-group" to Translatable and that's incorrect. I've configured it to "Not Translatable" and it seems to work now. Could you check?
Also, please update all WPML plugins to the latest version when you have a backup prepared.
February 10, 2026 at 9:45 am #17807843
vadimP
Thank you for your response. You've mentioned ACF fields, however we don't have an issue with those. The question was about Product Field Groups plugin, which is separate (Advanced Product Fields Pro for WooCommerce).
I will include screenshots for clarification.
The last few screenshots is our team trying to translate one of the field groups via automatic translation. It seems to work on the surface, the EN version is added, but when you go to check - it's empty. The fields that are present in LV version are not there in EN.
WPML plugins are updated.
February 10, 2026 at 3:21 pm #17809887
Thanks for your reply, and apologies for the confusion earlier.
I’ve checked your primary product field group here hidden link , and it is correctly translated into English here hidden link .
Could you please let me know how this product field group is being used on the product? Since everything looks correct in the backend, the next step would be to verify the frontend output.
February 13, 2026 at 9:40 am #17819874
vadimP
Can you please show what you mean by "correctly translated"? As you can see in the screenshots, the fields are exactly the same in both language versions. In this case EN was simply duplicated from the original LV version, no translation has taken place. And if you check the translation editor screen, it's empty except for the title.
Our goal is to use automatic translations via translation dashboard, as described in my previous message. If you go to translation dashboard, select any of the untranslated Product fields and try automatic translation, you will be able to test that it doesn't work.
Even if we wanted to translate each product field group via the advanced translation editor, it is not possible (as shown on the screen - only title is available for translation).
And manual translation of each field is not a feasible option for us because of the huge volume of content.
February 13, 2026 at 4:18 pm #17821374
Thanks for your reply. My apologies for my mistake. I can see the issue now. I will need a snapshot of the site to troubleshoot this further locally. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded. https://wpml.org/de/faq/provide-supporters-copy-site/
2. If the archive file exceeds 400MB, please use Duplicator's file filters to exclude cache, wp-uploads directory, media, and archive files.
February 16, 2026 at 9:42 am #17824949
vadimP
Hi, thank you for your response.
"Alternatively, with your permission, I can create one myself." - Please go ahead with creation of a snapshot via Duplicator or another method that is most convenient to you. Let me know if anything else is required from our side.
February 16, 2026 at 5:18 pm #17826656
Thanks for your patience. I have the package now and I will check and revert back to you as quickly as possible.
February 16, 2026 at 6:05 pm #17826735
Thanks for your reply. I’ve checked, and it appears that Advanced Product Fields Pro for WooCommerce requires manual translation, as explained here: https://wpml.org/plugin/advanced-product-fields-for-woocommerce/ (Only the premium version of this plugin supports manual translation with WPML)
You can follow the instructions in this guide to translate the product fields: hidden link
My apologies for the earlier misunderstanding regarding your issue.
The topic ‘[Closed] Issue with translating Product Field Groups’ is closed to new replies.
