If you're experiencing issues with translating the 'Read More' button text in the Kadence Post Grid block, we have a solution for you.
First, add the following custom XML configuration to your site:
<wpml-config>
  <gutenberg-blocks>
    <gutenberg-block type="kadence/postgrid" translate="1">
      <key name="readMoreText"></key>
    </gutenberg-block>
  </gutenberg-blocks>
</wpml-config>
You can do this by navigating to WPML > Settings > Custom XML Config. After adding the custom XML, edit the button text on your homepage, save the page, and translate it again.
We have also escalated the issue to our compatibility team and updated the wpml-config.xml file for Kadence. We are currently testing the plugin and collaborating with the author to resolve any issues.
If this solution doesn't seem relevant to your problem, please open a new support ticket with us.
Last updated by Andreas W. 1 year, 5 months ago.
January 13, 2024 at 11:28 am
marioL-27
- Try to recreate on sandbox and create custom XML for block
- Escalate to compsupp for keeping track of the issue
January 13, 2024 at 11:56 am
January 13, 2024 at 4:35 pm #15181674
To be able to try to recreate this issue on my test site the plugin "Kadence Blocks - PRO Extension" seems to be required.
Would you please be so kind as to install the plugin for testing purposes on the following temporary test site?
One-Click-Login:
Please leave me a short message on this ticket once you are done with this task.
January 13, 2024 at 5:09 pm #15181683
marioL-27
Hi Andreas,
Thanks, happy to do that.
I've installed an activated the pro extension to your site now.
- Mario
January 13, 2024 at 5:58 pm #15181701
Hello Mario,
The config for this button is:
<wpml-config>
  <gutenberg-blocks>
      <key name="readMoreText" />
    </gutenberg-block>
  </gutenberg-blocks>
</wpml-config>
You can copy and paste this config to WPML > Settings > Custom XML Config. (I did this already on your site)
Now, simply edit the button text on your homepage, save the page, and translate it again.
I am escalating this to our compatibility team, so that they can update our remote repository, as in this case, we are supporting Kadence on this matter - I am only not 100% sure if we also provide support for their PRO extension.
I will keep you updated once I received feedback from the compatibility team.
January 13, 2024 at 6:27 pm #15181713
marioL-27
Awesome! Let's see what your compatibility team things.
I went ahead and added successfully the translation on the front end.
January 13, 2024 at 6:48 pm #15181727
I am glad to hear that we were able to find a quick solution to the issue.
Once I receive feedback from the team I will be in contact with you again.
Have a nice weekend 🙂
January 17, 2024 at 3:10 pm #15195683
We updated the wpml-config.xml file and made it available for Kadence.
Take kindly note, that we are currently testing the plugin and working together with the author in solving any occuring issues.
Thank you for your patience!
January 17, 2024 at 9:04 pm #15197180
marioL-27
Hi Andreas, thank you for the update!
All good, our site is anyways working now as intended, so we're happy. 🙂
January 17, 2024 at 9:07 pm #15197182
Thank you very much for your message and the confirmation.
Have a nice day!
