Last updated by Marcel 1 month, 1 week ago.
Assisted by: Marcel.
March 6, 2026 at 1:15 pm #17877913
Jim Servaas
My product translation won't sync new adjusted manual added productattribute:
hidden link the colour is set to: Colour
Yellow / Transparent
But if you check this page in Dutch: hidden link the colour is still: Colour
Pink / Transparent
And I can't change this on the Dutch product, because the field is locked.
March 9, 2026 at 9:07 am #17881104
Marcel
I would eventually also need to request temporary access (WP-Admin and FTP) to your site
in order to be of better help and check if some configurations might need to be changed
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
✙ Please add the Links to the […] Edit Screen, the Page/Post where you insert the […] and the corresponding Front End Page/Screen
Best Regards,
Marcel
March 18, 2026 at 8:55 am #17906773
Jim Servaas
I need some time to create a test site
March 19, 2026 at 2:02 pm #17911360
Marcel
Sure, no worries. If it’s easier for you, you can also share a Duplicator package for local investigation: https://wpml.org/ko/faq/provide-supporters-copy-site/.
Marcel
The topic ‘[Closed] Manual added attribute won’t sync with translated product because it’s locked.’ is closed to new replies.
