This topic contains 14 replies, has 0 voices.
Last updated by Shekhar Bhandari 4 days, 16 hours ago.
August 14, 2025 at 5:19 am #17319608
smackcoders
I have a multilingual WordPress site using WPML, supporting four languages: English (default), Spanish, Japanese, and Arabic. All translations are created manually from the English content. I do not use automatic translation. I expected translated pages to remain in their correct language content after editing the default English content.
Whenever I make changes to the English version of a page/post and save it, after a day or two, one of the translated versions gets overwritten with the English content. This issue does not consistently affect all languages. For example, the Spanish version was replaced with English text after an edit, while Japanese and Arabic versions were fine. In another instance, the Japanese translation was overwritten instead.
Why are my manual translations being overwritten with English content after editing the default language?
How can I prevent WPML from overwriting my manual translations in the future?
August 19, 2025 at 8:06 am #17330106
smackcoders
Hi Shekhar Bhandari,
I’ve created a staging site to test the WPML issues. Could you please let me know the best way to share the credentials with you?
August 19, 2025 at 10:14 am #17330770
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
Sure, To debug this issue further, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
Note:
Look forward to your reply.
August 19, 2025 at 12:06 pm #17331129
smackcoders
I have shared the WP-admin and FTP access details. Please check and let me know the issues along with the fix. This is quite serious, as I have lost a significant amount of traffic due to this issue.
August 20, 2025 at 4:26 am #17333007
Shekhar Bhandari
Hello there,
Can you please share few post links from the staging where I can replicate the issue?
August 20, 2025 at 6:01 am #17333075
smackcoders
You can edit the following posts in the English language and make any changes needed:
Additionally, you can edit this page using Elementor in the English language, make your changes, and then publish:
August 20, 2025 at 6:32 am #17333109
Shekhar Bhandari
Hello there,
Your site shows "Error establishing a database connection" can you please fix it?
August 20, 2025 at 7:44 am #17333288
smackcoders
I’ve fixed the issue. You can test it now.
August 20, 2025 at 8:15 am #17333437
Shekhar Bhandari
Hello there,
Thank you for the fix.
I have made some changes to this page: hidden link
I will keep monitoring if it overrides the translations, right now I don't see any issue with it.
August 20, 2025 at 12:52 pm #17334290
smackcoders
Thanks for the update. I’m also monitoring this page. If you need to update any other pages, feel free to do so.
August 21, 2025 at 4:23 am #17335814
Shekhar Bhandari
Hello there,
I just checked the pages I made changes and I can't reproduce the issue till now.
August 22, 2025 at 5:27 am #17339385
smackcoders
Hi Shekar,
I have made some changes in these pages also:
We can track these pages as well.
Can you give some time to reflect on the issues? Because I don't know when the issues occur, I manually checked and identified them.
August 25, 2025 at 4:49 am #17343756
Shekhar Bhandari
Random issues are challenging to debug and resolve. Your experience is similar to that of others, and a short-term fix is not feasible. It will require a longer timeframe.
I have already provided suggestions for controlling this behavior. The next step is to identify the root cause, although we cannot guarantee that we will find it at once.
If the issue occurs again, we will need to disable all plugins and switch to the default theme. This process will take time.
I hope you understand.
Thank you
August 27, 2025 at 4:48 am #17349876
smackcoders
Ok, I understand. I’ll follow the instructions to prevent the issue:
Not opening the page in a new tab (to avoid confusing the translation).
Editing in the WordPress editor (already done).
Just to confirm, are these the correct steps, or am I missing anything?
If the issue still occurs after this, should I contact you again?
August 27, 2025 at 5:01 am #17349879
Shekhar Bhandari
Yes, those are the steps.
and yes feel free to contact us if you need any further help.
