Problem: If you're experiencing issues with displaying different language videos on different domain extensions using Woothumbs and WPML, and need to replace a video URL rather than uploading a new image in the WPML > Media Translation section. Solution: We recommend following these steps: 1. Navigate to Woothumbs > Performance and disable Image Caching. 2. Go to WPML > Settings > Custom Fields Translation and click on Show system fields. 3. Set the
_iconic_woothumbs_media
field to copy-once and save. 4. Access the Media Library, select the image, switch the language, and set a different video URL.
We applied these steps to a sandbox site to verify the solution. If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket for further assistance at WPML support forum.
1) After translating any media attachment, You need to click the scan and replace button. (Kindly check the attached screenshot)
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Preferably to a test site where the problem has been replicated.
Please add the data to the private field. If you don't see the form below, please don't add your credentials, as they will be publicly exposed٫ (hidden link)
It's back online. I deactivated the plugins to check the issue in the minimal setup, but that also deactivated the one-time login plugin, so please share the site's access details.
I deactivated the plugins, and the image appeared to be correct. Please activate your plugins one by one and check the image to know which plugin causes this issue.
