If you're experiencing issues with displaying different language videos on different domain extensions using Woothumbs and WPML, and need to replace a video URL rather than uploading a new image in the WPML > Media Translation section.
We recommend following these steps:
1. Navigate to Woothumbs > Performance and disable Image Caching.
2. Go to WPML > Settings > Custom Fields Translation and click on Show system fields.
3. Set the
_iconic_woothumbs_media
field to copy-once and save.
4. Access the Media Library, select the image, switch the language, and set a different video URL.
We applied these steps to a sandbox site to verify the solution. If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket for further assistance at WPML support forum.
This topic contains 35 replies, has 2 voices.
Last updated by Osama Mersal 5 months, 1 week ago.
Assisted by: Osama Mersal.
September 13, 2024 at 9:21 am #16174823
markB-105
Hey Osama,
I applied the video to the dutch product:
However, when I translate the media for the english product, it is not showing the video play button on the image gallery:
September 13, 2024 at 8:16 pm #16177702
Osama Mersal
Thanks for your reply. I'll consult our compatibility team regarding this issue and update you as soon as they reply.
Osama
September 17, 2024 at 4:12 pm #16189814
markB-105
Thanks Osama! Waiting for your reply
September 17, 2024 at 4:18 pm #16189865
Osama Mersal
Please check the following steps:
1- Go to Woothumbs > Performance and disable Image Caching (important)
2- Go to WPML > Settings > Custom Fields Translation and click on "Show system fields"
3- Set the _iconic_woothumbs_media field as copy-once and save
4- Go to Media Library and select the image
5- Switch the language and set a different video URL
I've applied these steps to the sandbox site. Please check if it works correctly. (hidden link)
Osama
September 18, 2024 at 10:44 am #16192463
markB-105
Hi Osama,
Thanks for your message. I tried everything till step 4, but I can not find the translated media I applied in our Media Library to set the different video URL.
I tried it on this product:
September 18, 2024 at 11:28 am #16192667
Osama Mersal
I don't have the login details for the staging site, but in order to check the translated media, please go to Media-> Library, select the image, click Edit with more details, and switch the language from the top admin bar.
Osama
September 18, 2024 at 12:14 pm #16192891
markB-105
Thanks Osama, works perfect now!
