I am trying to translate the label inside the Adv Header block of Kadence. Your support had a solution for this with the use of 'Adv Heading' XML, but that overwrites the entire Row Layout/Column structure and does not translate anything else for the Adv Heading. The issue can be seen at: hidden link
The Menu label should be 'Menü' but it is not properly working. Instead, I see the English word 'Menu'.
How can I translate the menu label inside the Kadence Adv Header block without overwriting the entire Row Layout/Column structure?
