I am trying to translate the label inside the Adv Header block of Kadence. Your support had a solution for this with the use of 'Adv Heading' XML, but that overwrites the entire Row Layout/Column structure and does not translate anything else for the Adv Heading. I need a more robust method for this. The issue can be seen at: hidden link
The Menu label should be 'Menü' but it is not properly working. Instead, I see the English word 'Menu'.
How can I translate the menu label inside the Kadence Adv Header block without overwriting the entire Row Layout/Column structure?
Thanks for contacting us. Sorry to hear that the solution I provided earlier did not help. I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
This conflicted with the Row Layout and Column Adv Headings as it is now only set to translate a // span inside the Adv Heading, which is also happening inside the Row Layout on other pages. So perhaps we need to specify this block that it's the Adv Heading inside a Header block?
I read through some other articles and found this:
<gutenberg-block type="kadence/advancedheading" translate="1">
<xpath>//*[self::h1 or self::h2 or self::h3 or self::h4 or self::h5 or self::h6 or self::p or self::div or self::span.wp-block-kadence-advancedheading]</xpath>
<xpath type="link">//a/@href</xpath>
</gutenberg-block>
Right now we set the Adv Heading block to only translate //span, but there are other blocks that use it as a H1 or a H2, or even a P. Could this be the solution?
Thanks for getting back to me. I’ll need to see a clear example where the custom XML configuration is affecting the Row Layout and Column Advanced Headings. Could you please clone the site to a staging environment and try to reproduce the issue there? Once replicated, I can review it and adjust the custom XML configuration accordingly.
Hi Kor! I am not able to replicate the issue on a staging environment without a whitelist (as per our server configuration). Are you able to make a clone?
It seems like this xml markup could do the trick:
</gutenberg-block>
With span, you are actually saying that only the //span for each Adv Heading block can be translated. Since there are other Adv Heading blocks used throughout the website, this is logical behavior and I think using the above solution (which is in your documentation) could work, what do you think?
The one that I've provided should be correct. Could you share a screen recording showing me what breaks when you use the custom XML configuration that I've provided?
The topic ‘[Closed] Menu label inside Kadence Adv Header block does not translate (but get’s picked up in ATE)’ is closed to new replies.
