This topic contains 0 replies, has 1 voice.
Last updated by petrL-10 4 months, 4 weeks ago.
March 7, 2025 at 1:02 pm #16788483
petrL-10
I am trying to use WPML with Elementor on my site hidden link. I recently purchased WPML and am attempting to add Elementor elements.
I can't add Elementor elements like Accommodation Types Carrousel when using WPML.
Why can't I add Elementor elements like Accommodation Types Carrousel with WPML?
March 7, 2025 at 1:49 pm #16788885
petrL-10
Another thing is missing the header and footer from Elementor.
March 7, 2025 at 2:43 pm #16789066
Lucas Vidal de Andrade
WPML Supporter since 11/2023
Hey there,
I checked your theme and plugins, and it seems that the "Accommodation Types Carrousel" is a custom Elementor widget. It's likely that the author of your theme haven't made it multilingual ready, so you will need to register it manually. You can check the steps here:
https://wpml.org/documentation/support/multilingual-tools/registering-custom-elementor-widgets-for-translation/
In a nutshell, you must install and activate the Multilingual Tools plugin, visit the page's WP Editor, copy the XML of the unregistered widgets, and paste it in WPML > Settings > Custom XML Configuration. After that, make a small change to the original page and save, and update the translation. Let me know how it goes.
As for the header and footer, if they were built with Elementor, they must be translated via WPML > Translation Management.
Check here: https://wpml.org/documentation/plugins-compatibility/elementor/
March 7, 2025 at 3:16 pm #16789128
petrL-10
I followed your steps, but they did not work.
Can I please give you access to check it?
March 7, 2025 at 5:18 pm #16789551
Sure.
I would like to look at this directly on your site. For this I would need temporary access (WP-Admin and FTP) to your site, preferably to a test/staging site where the problem has been replicated if possible.
I may need to replicate your website locally. To do this, I need to temporarily install a plugin called "Duplicator" or "All in One WP Migration" on your website. This will allow me to create a copy of your website and content. Once the issue is resolved, I will delete the local website. Let me know if this works for you.
IMPORTANT
Please make a backup copy of the site files and database before giving us access.
- If you do not see the wp-admin/FTP fields, this means your post and site login details are being made PUBLIC. DO NOT post your website details if you do not see the required wp-admin/FTP fields. If you do not, ask me to enable the private box. The private box looks like this:
March 7, 2025 at 5:56 pm #16789595
petrL-10
Please fix the issue with the header and footer too. I appreciate it. Thank you.
March 10, 2025 at 11:51 am #16796246
Hey there,
I'm still checking your issue and will get back to you soon.
March 10, 2025 at 1:32 pm #16796770
Hey there,
Thank you for sharing access. Your theme and plugins required some additional settings to be translatable, I changed them already.
Regarding the accommodations, they are still untranslated. Please make sure to have a full website backup, go to Accommodations > Accommodations Types and Accommodations and translate them. You can simply click on the "+" icon and add the translation. Finally, make a small change in the page that contains the carousel and update the translation. That should solve it.
As for the headers and footers, you can do the same. Visit the page where they are listed and add the translations. Let me know hos it goes.
The Spanish version of the website is protected, so I couldn't check it myself.
Headers _ Apartments_ Albergue Lecer and Casa de Millares - Sobrado _ WordPress.jpeg
March 10, 2025 at 2:40 pm #16797102
petrL-10
Hi Lucas,
I hope you're doing well.
I would prefer not to use the WPML method for translation. Instead, I'd like to simply make a copy and translate it using Elementor.
However, I'm unable to do so because Elementor gets stuck on the loading screen when I attempt to translate it into Spanish.
Could you please let me know why Spanish is locked and how I can unlock it?
Thanks in advance for your help!
March 10, 2025 at 7:19 pm #16798235
Please tell me the exact steps you took, so I can understand the translation method you came up with. Alternatively, you can share a screenrecording using Loom, so I can check how you are creating the duplicates.
Let me know.
March 10, 2025 at 9:07 pm #16798575
petrL-10
March 11, 2025 at 6:18 pm #16803574
Hey there,
I've tried in many different ways to create a copy of your website, but it simply wouldn't work.
Please check if you can do it on your side. Go to All In One WP Migration > Backups and download the available backup. Upload it to Google Drive and share the link with me. I've enabled the private field, which you can find under the text box for you to share the link safely.
Let me know.
March 12, 2025 at 3:51 pm #16808202
Hey there,
Thank you so much for sharing the copy. In the local copy, I realized that the issue is exclusive to Acommodation Types. This indicates that this is a compatibility issue between WPML, Elementor and the MotoPress Hotel Booking plugin.
To confirm that, I've created a fresh installation of WPML. You can access it with the link below:
In this fresh install, please do as follows:
1. Install Elementor
2. Install MotoPress Hotel Booking
3. Create an accommodation type, using Elementor. The content is not important, you can add a paragraph only;
4. Switch the translation option to "WP Editor";
5. Open the translation and click to edit with Elementor;
Let me know if the behavior is the same. The idea here is to test the feature in isolation, so please don't import or create any content, or install any unnecessary plugins. Let me know how it goes. I know this takes some effort, so thanks in advance for the cooperation.
March 12, 2025 at 9:03 pm #16809232
petrL-10
Hi Lucas,
I really appreciate all your help and effort, but things are becoming a bit too complicated for me.
I’ve decided to request a refund. Thank you again for your time and support.
