You are trying to create an English WooCommerce product feed in addition to a Dutch product feed using WPML.
We recommend using one of our officially compatible plugins, such as Product Feed Manager for WooCommerce. You can find a list of compatible plugins here: https://wpml.org/plugin/.
Please follow the official documentation on how to create a feed per language if that plugin supports it, available here: https://rextheme.com/docs/how-to-generate-product-feed-with-wpml/.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket at WPML support forum.
