- | 9:00 – 13:00 | 9:00 – 13:00 | 9:00 – 13:00 | 9:00 – 13:00 | 9:00 – 13:00 | - |
- | 14:00 – 18:00 | 14:00 – 18:00 | 14:00 – 18:00 | 14:00 – 18:00 | 14:00 – 18:00 | - |
Related documentation:
This topic contains 10 replies, has 1 voice.
Last updated by Bobby 1 month, 3 weeks ago.
Assisted by: Bobby.
March 13, 2025 at 10:44 pm #16813926 | |
tobiasH-57 |
Background of the issue: And I deleted the USD currency from the WooPayment native MultiCurrency selection to avoid confusion. Link to a page where the issue can be seen: hidden link Symptoms: Questions: |
March 14, 2025 at 9:45 am #16815564 | |
Andreas W. WPML Supporter since 12/2018 Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: America/Lima (GMT-05:00) |
Hello, Do you have Multi-Currency enabled in WooPayments? If so, please disable this feature and test again. Best regards |
March 15, 2025 at 1:33 pm #16819894 | |
tobiasH-57 |
Hi Andreas, Best regards |
March 17, 2025 at 6:44 pm #16826925 | |
Bobby WPML Supporter since 04/2015
Languages: English (English ) Timezone: America/Los_Angeles (GMT-07:00) |
Hi there, When I visit your site I cannot see the currency switcher anymore. Did you temporarily deactivate it? My only option is EUR. I also tested adding it to the cart and trying to checkout using a US address but it still remained in EUR. |
March 18, 2025 at 11:37 am #16829837 | |
tobiasH-57 |
Hi, for testing purposes I only have the currency switcher in the footer of the German version at the moment. So if you switch to German (or just remove /en in the URL) and scroll all the way down, you should be able to see and test it. Best regards |
March 18, 2025 at 6:15 pm #16832051 | |
Thank you, i missed that! 🙂 I was able to reproduce the issue and also catch it on screencast, here is the screencast for our records. hidden link The first time I tried it worked fine and switched from EUR to USD, the second time it did not until I went to another page and then it was in USD. This does look possibly related to caching. 1. What are your results if you temporarily deactivate caching then test in an incognito mode ? We have seen issues like this caused by Litespeed caching before. 2. Go to WPML->languages-> Language filtering for AJAX operations and enable Ajax |
March 21, 2025 at 10:06 am #16843591 | |
tobiasH-57 |
Hello, The problem with the switcher, not changing the currencies every time, is indeed related to Caching. When I deactivated the Litespeed Plugin it was switching as it should. So I guess there’s something else I need to exclude from Caching? Language filtering for AJAX was already activated. But the weird rounding of USD prices doesn’t seem to be connected to Caching. It didn’t change when Litespeed was deactivated. Best regards |
March 21, 2025 at 6:05 pm #16846148 | |
I can see that you have added the following cookies to your cache exclusion list: please add this one as well: wcml_client_currency If this does not resolve the issue, consider also adding WooCommerce pages to the exclusion list. Regarding the rounding, I will need to further review as it might not be related to this issue. Once we finish the caching issue I can take a further look and investigate separately Let me know your results, after doing the above. |
March 23, 2025 at 8:02 pm #16849244 | |
tobiasH-57 |
Hi, |
March 24, 2025 at 7:52 pm #16853897 | |
Is this something you could possibly test so we can confirm if this is indeed the issue here? If you don't have a staging site where this can be tested or don't feel comfortable testing on the live site, we can migrate a copy of the site onto our servers to continue testing. |
March 28, 2025 at 11:57 am #16872673 | |
tobiasH-57 |
Hi, In the meanwhile I tried setting the wcml_client_currency in Advanced > Vary Cookie, instead of Exclude Cookie. But that didn't help either. Now I also tried excluding all ^/shop/ pages, while leaving Caching activated on all other pages. That does indeed fix the problem. But of course it's important for me to keep those pages cached normally. |
March 28, 2025 at 10:46 pm #16874696 | |
I would like to request temporary access (wp-admin and FTP) to your site to test the issue. **Before we proceed It is necessary to take FULL BACKUP of your database and your website. Providing us with access, you agree that a backup has been taken ** I often use the Duplicator plugin for this purpose: http://wordpress.org/plugins/duplicator/ NOTE: If access to the live site is not possible and the staging site does not exist please provide me with a duplicator package created with the duplicator plugin. Thank you, |
April 1, 2025 at 1:47 am #16881193 | |
Thank you for the access details! On the staging site I have not been able to reproduce the issue, can you please try and let me know your results. Also on the live site try the following and let me know your results as well. add_filter( 'wcml_multicurrency_supported_cache_plugins', function( $plugins ) { NOTE: before trying any custom work provided by us or somebody else please make sure to have a working backup available. |
April 1, 2025 at 1:48 am #16881196 | |
April 1, 2025 at 4:38 pm #16883958 | |
tobiasH-57 |
Hi. I inserted your suggested code as a snippet in functions.php. After reloading in a private browser window nothing changed. |
The topic ‘[Closed] MultiCurrency is rounding wrong and not switching on current site’ is closed to new replies.
