This topic contains 16 replies, has 3 voices.
Last updated by Marcel 1 year, 8 months ago.
Assisted by: Marcel.
September 4, 2023 at 2:05 pm #14337717 | |
muhammetM |
hello, my site is the last time I started using wpml, but recently after it finishes turning the pages (translate the page) after clicking on the language, the site automatically goes into maintenance mode for no reason, I can't understand why it's doing it this way, it's only on the phone and sometimes it started doing it on the computer, what can I do please help...5 |
September 5, 2023 at 11:36 am #14343585 | |
Nicolas V. Supporter
Languages: English (English ) French (Français ) Timezone: America/Lima (GMT-05:00) |
Hi, Welcome to the WPML support forum. Thanks for contacting us. We are currently handling a high amount of ticket and while waiting for one of my colleagues to help with this ticket, please allow me to walk you through some initial debugging steps. This will help speed up the support process. We would need your WPML debug information. In short: Nico |
September 7, 2023 at 9:16 am #14357575 | |
muhammetM |
Hello Mr. NİCO yes now is in here Can you look at this field and what is happening here I have 3 sites have same problems as this... THANK YOU FOR ASSISTING ME. |
September 7, 2023 at 1:23 pm #14359875 | |
Marcel Supporter
Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: Europe/Madrid (GMT+02:00) |
Hi, my name is Marcel and I will take over your ticket. Do have a staging site where I can make some tests and isolate (deactivating components) to isolate the issue? I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it. Maybe I'll need to replicate your site locally. For this, I’ll need to temporarily install a plugin called “Duplicator” or "All in One WP Migration" on your site. This will allow me to create a copy of your site and your content. Once the problem is resolved I will delete the local site. Let me know if this is ok with you. IMPORTANT Best Regards |
September 7, 2023 at 3:05 pm #14360985 | |
Marcel Supporter
Hi, please note that I can't make these tests on a live site, as it they could break your installation. Do you have a staging environment where we can isolate it safely? If not, you can provide a duplicator copy of your site as described here: https://wpml.org/faq/provide-supporters-copy-site/. Then, I can isolate and debug locally, and we don't risk breaking anything on the actual live site. Thank You! Best Regards |
September 18, 2023 at 7:21 am #14409487 | |
muhammetM |
yes im okey with that can you look now at my site because all backup is ok now I waiting you |
September 18, 2023 at 7:25 am #14409557 | |
muhammetM |
sorry about a time Mr marcel work on tree site now |
September 18, 2023 at 7:52 am #14409721 | |
Marcel Supporter
Hi, the credentials are not working. I receive: "ERROR: Incorrect username or password.". Can you please check this? Thanks Best Regards |
September 18, 2023 at 8:11 am #14409797 | |
muhammetM |
now is open can you check thank you for your assistance |
September 18, 2023 at 11:56 am #14411555 | |
Marcel Supporter
Hi, thanks, the site access works now, but I receive "Connection failed." via FTP. Can you check this please? Best Regards |
September 19, 2023 at 3:37 pm #14421385 | |
Marcel Supporter
Hi, I receive via FTP "Can't change directory to /teswiky.com: No such file or directory". As best, you install an FTP plugin so that I can activate the debugging there. For example, this one: https://wordpress.org/plugins/wp-file-manager/. Best Regards |
September 19, 2023 at 5:23 pm #14422935 | |
muhammetM |
I'm okay with that I installed a plugin and you have access to do other work as you want. thanks for help |
September 20, 2023 at 1:40 pm #14430633 | |
Marcel Supporter
Thanks, it works now: hidden link Resaving the WP permalinks solve it (Settings -> Permalinks). Best Regards |
September 21, 2023 at 7:19 pm #14441851 | |
muhammetM |
hi Mr. Marcel the issuse is still in site, how we can improve it for this site same thinks it in the link form your mail Best regards, muhammet |
September 22, 2023 at 7:58 am #14444225 | |
Marcel Supporter
Hi Muhammet, all URLs I mentioned before are working: hidden link Screen video: hidden link You can open them also via https: hidden link If you are referring to the missing SSL certificate, this is not in control of WPML. You will need to contact your hosting company to redirect from http to https. Your WP instance runs as http: hidden link. Best Regards |
