The client needs help deleting WPML.
If you're experiencing issues with deleting WPML, we recommend you follow these steps:
1. Visit our documentation on Deleting Languages and Plugin Data by Doing a WPML Reset on Your Site.
2. Follow the guide to delete all translations.
3. Perform a WPML reset.
4. Disable and remove WPML from your site.
We hope this information is helpful to you. If this solution doesn't look relevant, please open a new support ticket.
Last updated by Mihai Apetrei 1 year, 5 months ago.
Assisted by: Mihai Apetrei.
January 13, 2024 at 4:46 pm #15181679
ergiA-3
need help deleting wpml
January 13, 2024 at 10:38 pm #15181780
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
Please follow the steps in our documentation URL below:
https://wpml.org/documentation/getting-started-guide/language-setup/deleting-languages-and-plugin-data-by-doing-a-wpml-reset-on-your-site/
This should guide you through deleting all the translations, then reset WPML and then disable + remove WPML from your site.
I hope that you will find that information helpful.
Mihai Apetrei
