You have translated a navigation button from French to English, but it still displays in French on your website.
If your menu is a standard WordPress menu, we recommend following the instructions provided here.
If the menu is part of a Divi template, you should go to WPML -> Translation Management, select the template, and translate it directly from there.
If this solution does not apply to your case, or if it seems outdated, please check the related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket if you need further assistance. You can do so at WPML support forum.
This topic contains 5 replies, has 1 voice.
Assisted by: Marcel.
