You are trying to translate certain strings on your site using WPML, but these strings, which were previously translated, have reverted back and are not appearing in the string translation menu.
If you're experiencing this issue, we recommend you try the following steps:
1. Navigate to WPML → String Translation.
2. Click on "Not seeing the strings you are looking for?" and then proceed to Admin Texts Translation.
3. Search for the strings and add them to the translation list.
4. Translate the strings.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
Last updated by Andrey 10 months, 1 week ago.
Assisted by: Andrey.
May 31, 2025 at 3:14 am #17093663
fadiS-3
I'm trying to translate some strings on my site hidden link using WPML. These strings were previously translated by the support team but have now reverted back.
The strings that require translation are on the top left in the screenshot i shared
The strings I want to translate do not show up in the string translation menu.
Why are the strings not appearing in the string translation menu?
How can I ensure the translations do not revert back?
May 31, 2025 at 7:28 am #17093764
Andrey
WPML Supporter since 06/2013
Have you tried the following steps?
1. Go to WPML → String Translation.
2. Enable the option to automatically register strings.
3. Navigate to the page where the untranslated strings appear.
4. Return to WPML → String Translation and check if the specified strings have been registered.
5. Translate the strings.
June 1, 2025 at 4:13 am #17094898
fadiS-3
hi, yes i have tried that and i see that the string is translated in the backend, but it doesnt show on the frontend. i have attached the screenshot as a reference
June 2, 2025 at 7:33 pm #17099326
Andrey
Thank you for your feedback.
June 3, 2025 at 7:40 am #17100462
Andrey
Thank you for providing the details.
I successfully translated the strings by following these steps:
2. Click on "Not seeing the strings you are looking for?" and then go to Admin Texts Translation.
I have attached the screenshots.
