- 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 -
This topic contains 23 replies, has 0 voices.
Last updated by Lucas Vidal de Andrade 12 hours, 1 minute ago.
March 27, 2026 at 1:13 pm #17932335
Webest
I have a new post (CPT: Listing) with custom fields and trying to translate. All the custom fields are set to "Don't translate" or "Copy" in WPML.
And when I click the gear icon
The translation editor launches.
I have 100% translation, click Save and Complete, the message "Success" translation completed appears, and it retursn to the previous view, i.e. the gear wheel.
I checked https://wpml.org/forums/topic/almost-all-pages-posts-remain-stuck-in-translation-progress-and-never-finish/ and tried this:
removed translation jobs, translations
WPML → Support → Troubleshooting
Remove ghost entries from translation tables
Synchronize local job IDs with ATE jobs
Clear the cache in WPML
March 30, 2026 at 10:12 am #17936043
Marcel
I would eventually also need to request temporary access (WP-Admin and FTP) to your site
in order to be of better help and check if some configurations might need to be changed
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
✙ Please add the Links to the […] Edit Screen, the Page/Post where you insert the […] and the corresponding Front End Page/Screen
Best Regards,
Marcel
April 2, 2026 at 9:51 am #17945474
Marcel
I receive an error: Error: "The username WPML-Marcel is not registered on this site". Could you pease check this?
Best Regards,
Marcel
April 2, 2026 at 11:58 am #17945887
Webest
Hi Marcel, I'm not sure if you got previous message, so I write again:
- please use for login hidden link
- username wpmp-marcel@webest.pl or WPML-Marcel
Thank you for any help!
Cheers
Danka
webest.pl
April 2, 2026 at 12:29 pm #17945960
Marcel
Hi Danka,
Thank you! It looks like there’s no general issue, since the other listings are working correctly.
I’d recommend deleting the “Test Listing New…” entry, clearing your basket, and then adding a new test entry.
Marcel
April 2, 2026 at 1:32 pm #17946222
Webest
Marcel, thank you. We also saw that for "old" listings it works well, but not the new one.
We will check again as you recommend anyway.
April 2, 2026 at 2:58 pm #17946500
Marcel
Hi Danka,
I was able to reproduce the issue using a new listing, but I’ll need to test it in isolation to investigate further. Could you please provide FTP access?
While troubleshooting, I had to deactivate the theme, which unfortunately triggered a fatal error. With FTP access, I’ll be able to restore and reactivate it safely.
Marcel
April 2, 2026 at 3:12 pm #17946519
Webest
Marcel, I have key information for you.
Other listings work correctly, but only with the WordPress editor. Old listings were translated differently (and very time-consuming).
Now want to speed up and make it easier and use the WPML Translation Editor for new listings (also fo existing ones) .
For testing, you have another completely new listing:
And the same situation; the translation isn't working correctly: hidden link
April 3, 2026 at 9:33 am #17947658
Marcel
Hi Danka,
thank you for the information. However, I still require FTP access to repair the staging site so I can continue testing this further.
Marcel
April 3, 2026 at 10:00 am #17947688
Webest
Marcel, FTP data is in message https://wpml.org/forums/topic/new-post-custom-post-type-remain-stuck-in-translation-progress-and-never-finish/#post-17939175 March 31, 2026 at 9:53 am
April 6, 2026 at 12:05 pm #17951330
Marcel
The previously shared FTP credentials appear to be for the live environment. Could you please provide the credentials for the staging environment instead?
Thank you!
Marcel
April 7, 2026 at 9:13 am #17953135
Webest
Hi Marcel, I'm sure that FTP with user "wprentals" is for staging.
We also see that there are some issues with staging. Let me know if you need any backup or something.
April 7, 2026 at 3:58 pm #17954851
Marcel
Hi Danka,
Thanks for your message. I had to deactivate the WP Rentals Core add-on in order to regain access to the backend.
Based on the information provided about the editor, I’m not yet able to clearly identify the root of the issue.
Could you please install WP Rentals in this hidden link isolated sandbox environment and check whether the same issue occurs when creating a listing? If the problem can be reproduced there, we can look into possible workarounds.
Marcel
April 8, 2026 at 10:44 am #17956456
Webest
Hi Marcel,
Could you please reinstall the sandbox here? hidden link
I've activated the wp rentals core plugin (reguired by the theme) but I should activate the theme first - now I can see a fatal error and I don't have FTP access to fix it..
April 8, 2026 at 3:02 pm #17957239
Marcel
I created a new Sandbox here: hidden link.
Best Regards,
Marcel
