I want to translate a Ninja Form on my website using WPML, but the form does not appear in the Translation Management or String Translation sections of WPML.
Ensure that the Ninja Form is published. Once published, it will appear in the WPML Translation Management list under the Ninja Forms filter. If it still doesn't appear, confirm that the Ninja Forms Multilingual addon plugin is installed and activated.
Relevant Documentation:
https://wpml.org/documentation/related-projects/creating-multilingual-forms-using-ninja-forms-and-wpml/
This topic contains 4 replies, has 3 voices.
Last updated by Christopher Amirian 8 months, 2 weeks ago.
August 26, 2024 at 12:13 am #16102132
orrog
I want to translate ninja form on my site hidden link, but I don't see it in translation management and string translation.
Ninja form don't appear in translation management and string translation.
How can I translate ninja form using WPML?
August 26, 2024 at 5:50 am #16102355
Dražen
Thanks for contacting us.
Please make sure you are using Ninja Forms Multilingual addon plugin:
- https://wpml.org/documentation/related-projects/creating-multilingual-forms-using-ninja-forms-and-wpml/
Drazen
August 26, 2024 at 6:53 am #16102661
orrog
thank you, but Ninja Forms Multilingual addon plugin is installed and activated, I cannot find where is my form for translation
August 26, 2024 at 11:15 am #16104105
Christopher Amirian
WPML Supporter since 07/2020
usually, if you go to WordPress Dashboard > WPML > Translation Management and from the top select the Ninja Forms and then click the filter button you should see the list of the forms that you created int he original language.
Screenshot:
If that is not the case, I'd appreciate it if you could give me the URL/User/Pass of your WordPress dashboard after you make sure that you have a backup of your website.
August 27, 2024 at 11:04 am #16109069
Christopher Amirian
The form was not published in Ninja Forms. As soon as I published the form it showed in the list.
August 27, 2024 at 2:36 pm #16110620
orrog
hi,
you say "The form was not published in Ninja Forms", but it was, look at attachment here : https://wpml.org/forums/topic/ninja-form-dont-appear-in-translation-management-and-string-translation-how-to-translate-it/#post-16102132
printscreen 048.
It's ok now, thank you
